Head/valve cover bolts
Re: Head/valve cover bolts
02 Jun 2016 08:32
Complicated by the fact there is no gasket.
03 Jun 2016 12:34 - 03 Jun 2016 12:35
Last edit: 03 Jun 2016 12:35 by 650ed.
- Sport-o
09 Jun 2016 14:53
Yes there is a tension guide ,figured the 1 to 2 mm difference would just wear off or tighten the chain just a little . I have only been around the block a couple times. Also yes the burning turned out to be just oil I missed while cleaning.
- 80B4
10 Jun 2016 15:16
This is why buying a used bike is such a crap shoot. RTV and improper assembly kill more engines than all other causes combined.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- Sport-o
- 80B4
12 Jun 2016 15:54
Good luck! I hate seeing these old bikes die. Please get a cam cover gasket and a factory service manual and treat that bike right.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
12 Jun 2016 17:5080B4 wrote: Good luck! I hate seeing these old bikes die. Please get a cam cover gasket and a factory service manual and treat that bike right.
Agree. First task: adjust the valves and get a proper gasket.
The following user(s) said Thank You: 80B4
- Sport-o
04 Jul 2016 19:30
Had to get the carbs rebuilt ,gas was leaking out the boot found a guy who did them for 20$.Got a gasket on order for the valve cover 600klm on it so far. Spending down time polishing. Will post a video of it running next time I drop by.
04 Jul 2016 19:36
$20? :ohmy: I charge $40 per carb. Hope he didn't mung them up.
- missionkz
04 Jul 2016 19:45HA ha $20 for four carbs?swest wrote: $20? :ohmy: I charge $40 per carb. Hope he didn't mung them up.
Can you spell Red Green?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- Sport-o
04 Jul 2016 19:55
Ya 20$ guess I'll find out Tommrow when I get them back on the bike. When I took the seat off to get it recovered I discovered that there was no air filter or cover. I assume driving it home and around the block the few times before I took the seat off did not help the carbs. Got a filter and found an old plastic cover kicking around in my garage that screwed on perfect,just had to cut a hole in the Center.
04 Jul 2016 20:13missionkz wrote:HA ha $20 for four carbs?swest wrote: $20? :ohmy: I charge $40 per carb. Hope he didn't mung them up.
:huh:
