Head/valve cover bolts
  • Sport-o
  • Sport-o's Avatar Topic Author
Re: Head/valve cover bolts
31 May 2016 18:42
#729413
No I did nothing in there just removed old gasket and used high temp silicone instead. I was thinking oil from the old leak maybe on the manifold
  • SWest
  • SWest's Avatar
  • 10 22 2014
31 May 2016 18:46 - 31 May 2016 18:46
#729414
No gasket?
Last edit: 31 May 2016 18:46 by SWest.
  • Sport-o
31 May 2016 18:49
#729415
This is where the smoke is comming from.
  • Sport-o
31 May 2016 18:50
#729416
No gasket
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • Sport-o
31 May 2016 19:00
#729418
Ya I plan on doing a total tune up/polish/paint over the winter.the only gasket I seen online was in Cali and I just wanna get this thing on the road or at least across town to my buddy's garage who at least knows what he's doing.
31 May 2016 19:07
#729419
I have never heard of a 4 cylinder 1984 KZ750-LTD. You may want to check the frame number to see if it might be a 1983 model.
The leak appears to me to be a very common one. The tach drive has a seal, gasket, and o-ring that eventually will leak and will need to be replaced. The oil often runs down and all around making it look like a different problem. Take a look at the link below for part numbers. Ed
www.powersportswarehouse.com/p/Kawasaki#...50-H4-1983/080119I-4
  • Sport-o
31 May 2016 19:27
#729422
Just checked 03/84 made in Japan!
  • Sport-o
31 May 2016 19:28
#729423
It's also shaft driven
  • Sport-o
31 May 2016 19:41
#729430
Ya it's a bit confusing for me to try and order parts,not May of these bikes left and not sure what crosses over. I am still not sure what its technical name is,as far as I can tell they were only sold in Canada. 1984 kz750ne Ltd shaft drive. Ok so it's only a seal and I don't have to worry about a piston ring or worse. Thanks for the help.
  • 80B4
  • 80B4's Avatar
02 Jun 2016 08:04
#729656
Isn't there a cam chain guide in the cylinder head cover on that engine? I've always thought that the cam chain tensioner had to be removed and reset when installing the head cover on those bikes in order to properly tension the chain. And if there was no gasket between the head cover and the head, wouldn't that effect the cam timing?
1980B4 1000
1978 Z1R
1978 B3 750
  • Nessism
  • Nessism's Avatar
02 Jun 2016 08:22 - 02 Jun 2016 08:26
#729660
80B4 wrote: Isn't there a cam chain guide in the cylinder head cover on that engine? I've always thought that the cam chain tensioner had to be removed and reset when installing the head cover on those bikes in order to properly tension the chain. And if there was no gasket between the head cover and the head, wouldn't that effect the cam timing?
This is correct. The cam chain tensioner spring cap must be removed before installing the valve cover otherwise the cam chain will become over tensioned.
That model bike uses an electronic tach so I don't think you need to worry about a leaking tach drive gear. The smoke is most likely residual oil burning off.
Last edit: 02 Jun 2016 08:26 by Nessism.
