strange noise
- kayodash
strange noise
20 Apr 2016 07:31 - 20 Apr 2016 07:37
Hello guys! So over the winter I picked up another bike. This one being a 1981 Kz750 ltd. Starts and runs, drives fine. It has developed a strange noise first noticeable around 1200rpm. Gets louder/more pronounced the lower the rpms. Idling around a grand sounds like its gonna break. I don't even know how to explain the noise.. But it isn't noticeable when I ride or idle at 15 grand... It seems to appear on the right side of the motor. Maybe lower end or middle? Can't hear it much on the left side.. I'll try to take video of it. Any ideas? The bike has about 36,000 miles on it. Maybe cam chain? Or tensioner? Possible valve Noise? I don't even know what to look up to see if it's somewhere in another post.
1984 Kawasaki KZ550 LTD F2
1981 Kawasaki KZ750 LTD
Last edit: 20 Apr 2016 07:37 by kayodash. Reason: wrong side
Re: strange noise
20 Apr 2016 07:39
The FIRST thing you should do is check the valve clearances. Then the cam chain adjuster if you have a manual one. The noise could be the carbs being out of sync. These engines can make frightening noises at idle like that. You also need a MANUAL.
Re: strange noise
20 Apr 2016 07:45
A disturbing sound at low idle rpm -- like digesting nails -- can usually be reduced or eliminated by a good carb sync.
And a good carb sync is predicated by valve clearances within spec, healthy fat blue properly timed spark, correct fuel levels, and ample fresh clean fuel supply.
Re: strange noise
20 Apr 2016 07:52
For a free downloadable KZ750 4-cyl service manual, use this link, and scroll down to "The Bible" ---
mbsween.bike-night.com/kz750l3/index.html
- kayodash
Re: strange noise
20 Apr 2016 17:11
Thanks for the fast replies! I'll start looking for a valve cover gasket and the end caps, also a vacuum gauge to sync the carbs. There's a link that shows the noise is making at 1000rpm
Re: strange noise
20 Apr 2016 17:23
Classic stumbling caused by out of sync carbs.
- missionkz
Re: strange noise
20 Apr 2016 21:05
Sounds like piston and cam chain slap from unbalanced cylinder fire, usually associated with misadjusted and unbalanced carbs.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Re: strange noise
20 Apr 2016 21:08
The smaller fours seem to make more noise than the large ones, still mine can make some alarming noises when out of sync.
- kayodash
Re: strange noise
17 May 2016 18:58 - 17 May 2016 19:09
Still making noise at a grand idle. Carbs ae synced. I think it may be the chain tensioner? I believe it's an automatic tensioner, it Has a lock screw in it. Any ideas guys?
Last edit: 17 May 2016 19:09 by kayodash. Reason: more idea
Re: strange noise
17 May 2016 19:19 - 17 May 2016 19:21
Are valve clearances within specs?
If mechanical timing advancer is fitted, would assure correct ignition timing at idle rpm and that the advancer is in good serviceable condition. clean and lubed.
Last edit: 17 May 2016 19:21 by Patton.
- kayodash
Re: strange noise
17 May 2016 19:23
Yes, valve clearances are in spec. Visually looking at the advancer it looks fine.
Re: strange noise
17 May 2016 19:27
Would check for alignment of advancer F mark with timing light at idle rpm.
