80 kz650 head gasket
  • aenikolopov
  • aenikolopov's Avatar Topic Author
08 Apr 2016 11:54
#719882
Hi all.
Noticed some oil leaking around my head gasket. Looked closer, and when the bike is running I can actually see a bit of bubblnig around the head gasket (on side, by cyl 4). Cyl 3 not running, spark plug fouled, but I had flooded it right before this was all noticed and had set the bike away for a couple days before dealing w/ it ). engine runs with choke on with only the 3 cyls. When checked at time of setting valve clearance 200 miles ago, cyl 1 pressure had dropped from about 145 psi to 120psi (though it's mildly possible that the gauge wasn't sealing properly), from the last time I had checked it about 3000 miles ago. other cylinders were still at about 145psi.
I suppose my question is, is it 100% a blown head gasket? Can I maybe just tighten the bolts and see if it changes anything? Certainly I need to check pressure, which i haven't done.
  • Nessism
  • Nessism's Avatar
Re: 80 kz650 head gasket
08 Apr 2016 14:11
#719900
If you are seeing bubbling from the gasket it's done for. You can try to torque the head nuts, which is listed in the factory manual as a regular maintenance item, but I doubt it will help at this point.
Any time you pull the head to fix a gasket it's highly advised to also pull the cylinder and replace all gaskets, seals, O-rings in the top end at the same time. Also, use OEM Kawasaki gaskets if you value oil tightness. Kawasaki doesn't sell a "kit", you have to piece together what you need by ordering one part at a time.
  • aenikolopov
08 Apr 2016 14:24
#719904
Nessism wrote: Any time you pull the head to fix a gasket it's highly advised to also pull the cylinder and replace all gaskets, seals, O-rings in the top end at the same time. Also, use OEM Kawasaki gaskets if you value oil tightness. Kawasaki doesn't sell a "kit", you have to piece together what you need by ordering one part at a time.
Will hit the wallet a bit just in parts. that kawi head gasket is 120 alone on z1. I'll make a list of parts and check in to see if people think it's sufficient. I should be able to do all this without removing the engine, correct?
  • Nessism
  • Nessism's Avatar
08 Apr 2016 14:33 - 08 Apr 2016 14:34
#719905
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configuration
Correct on leaving the engine in the frame. Be sure to change the valve stem seals while you are at it.
Often times you can get OEM gaskets for cheap off ebay. Find the part numbers and then go searching.
Last edit: 08 Apr 2016 14:34 by Nessism.
  • SWest
  • SWest's Avatar
  • 10 22 2014
08 Apr 2016 15:59
#719922
Check out my 'good guys" thread. I've had good luck with them. I use a pone piece head gasket. NO MORE OIL ON MY FOOT. :pinch:
The following user(s) said Thank You: aenikolopov
  • aenikolopov
11 Apr 2016 09:29
#720340
Nessism wrote: If you are seeing bubbling from the gasket it's done for. You can try to torque the head nuts, which is listed in the factory manual as a regular maintenance item, but I doubt it will help at this point.
Thanks. So, I've tracked down a reasonably priced kawi head gasket for $46, now on to the other things. Could someone direct me to a list of exactly what there is to change in the top end?
1) OEM kawi head gasket.
2) base gasket (planned on cutting this out myself, is that a bad idea?)
3) valve stem seals (8x)
4) .. what else? what o-rings are there? Any other seals? I have a month old valve head gasket, so not that. piston rings?
  • Nessism
  • Nessism's Avatar
11 Apr 2016 09:46
#720351
Bad idea to cut a base gasket. The material choice is critical and it's not an expensive gasket anyway.
For all the various parts you can go to Kawasaki.com and look up the parts diagrams for your bike in the Owners support section of their website. You will have to look at a number of different pages including those for the crankcase, cylinder, cylinder head, valve cover, valves, etc. Look through them all and make a list of the parts. Just going off the top of my head but you will need: base gasket, base gasket O-rings, O-rings around the cylinder studs, head gasket, O-rings for the head gasket, valve stem seals, cam plug rubber seals, valve cover gasket, cam chain tensioner seals and gaskets, tach drive O-ring and seals. Do them all and be done with it for the next 30 years.
  • pete greek1
  • pete greek1's Avatar
11 Apr 2016 10:28
#720368
There's a member here, you can P.M. him, DFIGPZ, he sells sets of Viton valve stem seals for 22.00 delivered
Pete
11 Apr 2016 11:14 - 11 Apr 2016 11:15
#720374
aenikolopov wrote: .............
2) base gasket - planned on cutting this out myself, is that a bad idea?.....
Bad idea. Keep in mind that the thickness of the base gasket is critical because it affects the height of the cylinders and head above the bottom case which in turn affects the compression ratio. Ed
Last edit: 11 Apr 2016 11:15 by 650ed.
  • aenikolopov
11 Apr 2016 11:38
#720380
pete greek1 wrote: There's a member here, you can P.M. him, DFIGPZ, he sells sets of Viton valve stem seals for 22.00 delivered
Pete
Thanks Pete, I'll send him a message.
  • aenikolopov
11 Apr 2016 11:39
#720381
Nessism wrote: Bad idea to cut a base gasket. The material choice is critical and it's not an expensive gasket anyway.
Ah, right. I hadn't thought about thickness affecting effective height of cylinder. Of course. thanks.
  • aenikolopov
11 Apr 2016 11:45
#720382
I'll look through that and put together a list. thanks.
