- Thank you received: 133
Trick to reinstalling tach gear?
- Topper
04 Apr 2016 16:44 #719270
by Topper
Permanent and perpetual noob.
1979 KZ750 Twin
2009 Kawasaki Versys
Trick ti reinstalling tach gear? was created by Topper
Help me out, I gotta be missing something simple. I replaced the tach guide, o-ring, and seal on my 79 KZ750.
The oil leak I was trying to fix seems to be gone. But the tach's not working.
I pulled the cable off and fired up the engine and confirmed the tach gear isn't spinning.
Is there some trick to reinstalling the tach gear? I've tried and tried to get it to mate up with the worm gear on the cam. But nothing is working. Feeling like a total noob here. What am I missing?
1979 KZ750 Twin
- Thank you received: 2749
04 Apr 2016 17:16 - 04 Apr 2016 17:17 #719276
by SWest
Replied by SWest on topic Trick ti reinstalling tach gear?
Can you pull it out to see if it is broken off? I bent one putting my cam in years ago. There is a bevel at the helical gear. It's pretty weak.
Last edit: 04 Apr 2016 17:17 by SWest.
- Topper
04 Apr 2016 17:32 #719279
by Topper
1979 KZ750 Twin
Replied by Topper on topic Trick ti reinstalling tach gear?
Yeah i pulled the tach gear back out and it looked fine.
1979 KZ750 Twin
- wrenchmonkey
- Thank you received: 75
04 Apr 2016 17:41 #719281
by wrenchmonkey
Replied by wrenchmonkey on topic Trick ti reinstalling tach gear?
I've only ever removed / installed these 3 times and none were on a '750 but they were always such a herculean effort to get it pulled out. Liberal amounts of PB were always needed with much back 'n forth on the spark plug socket to finally tease it free of the case.
The point being, the oxidation seems to make the bore really resistant to putting the gear back in, so is it possible that you're just not getting it to seat fully inward and possibly allowing the gear to simply flex below the camshaft's mating gear instead of seating into the case and engaging the cam?
04 Apr 2016 17:50 #719284
by SWest
What I don't understand is it goes beneath the cam. When the cam turns it is forced to the stop behind it and can't go anywhere. Is it possable you have the cams reversed? Not being a smart A$$ but just asking.
- Topper
05 Apr 2016 03:39 #719328
by Topper
1979 KZ750 Twin
Cams are right and the tach worked before i pulled the tach gear.
I guess I'm going to pull the valve cover and see if i can tell what's up.
1979 KZ750 Twin
- Topper
16 Apr 2016 10:06 #721218
by Topper
1979 KZ750 Twin
Well, I don't know how I did this, but this is clearly the problem.
I thought I was pretty careful inserting the tach gear. But apparently not careful enough.
I'm going to start a new thread about just how screwed I am here.
Attachment 14608257374070[1].jpg not found
1979 KZ750 Twin
16 Apr 2016 14:09 #721255
by SWest
:ohmy: OMFG. I hope the head is OK at least.
