kz750 / kz400 Coil bad? Replacement options?
- Oldercrow
28 Mar 2016 07:55
I have a 1979 kz750 and a 1976 kz400 and both are turning over, have gas, cleaned carbs but drive a bit weakly and then die. Seems like there could be a coil issue for both.
I saw a few videos on youtube showing how to test the ohm's on the coil. What is the best way to test the coils and deduce what's wrong?
Also, if I was going to replace the coils, would the Dyna 5 ohm coils Z1 sells be a good choice or should I go OEM?
www.z1enterprises.com/product/DYDC8-1-single
Thanks for any info!
Re: kz750 / kz400 Coil bad? Replacement options?
28 Mar 2016 08:05
Dyna's are good coils. I have no complaints with mine. If you have points 5 OHM is OK.
- loudhvx
28 Mar 2016 08:06
The dyna 5 ohm is good if you for sure sticking with points. If you do, try to make sure the dwell angle is near the long end of the range... like 195 degrees. That means the points are closed a little more than half of a crank rotation.
Otherwise, there are 4-ohm options that look like the stock coils. I usually see them on ebay etc.
If you might go with electronic ignition in the future, then the Dyna 3 ohm may be a good choice in the interim. If you go with them, make sure the dwell is just a little under 180 degrees. That means the points are closed a tiny bit less than half of a crank rotation.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
28 Mar 2016 08:10
I have 4 OHM. I can change lanes if I want to. :lol:
The following user(s) said Thank You: Oldercrow
- Oldercrow
28 Mar 2016 08:20
Thanks for the reply!
Would those ebay 4ohm's be a good quick fix just to get running? Not doing a full restore at this point, just getting some bikes ready for new riders.
28 Mar 2016 08:23
All I can say is you'll rule out one possibility. Coils get old and can fail in many ways.
- loudhvx
28 Mar 2016 09:51It may be quick and cheap, but it may also be a permanent fix, for a few decades.Oldercrow wrote: Thanks for the reply!
Make sure the listing says 4 ohms, or ask the seller. The 2.4 ohm coils look similar, but they will burn up the points.
They are the black ones that look like the stock coils (some of the stock coils were different color, though). The only issue is the mounting bolt spacing. If that's not listed, ask the seller. There are a few different spacings among Kz's, so you'll want to measure the old ones.
1981 KZ550 D1 gpz.
Other links.
Other links.
- Oldercrow
28 Mar 2016 09:59
Can running a 5 ohm hurt anything?
- bountyhunter
28 Mar 2016 12:39Won't hurt a thing.Oldercrow wrote: Can running a 5 ohm hurt anything?
- bountyhunter
28 Mar 2016 12:45
Here is one that should work:
Oldercrow wrote: I have a 1979 kz750 and a 1976 kz400 and both are turning over, have gas, cleaned carbs but drive a bit weakly and then die. Seems like there could be a coil issue for both.
- Oldercrow
28 Mar 2016 12:46Please Log in or Create an account to join the conversation.
- bountyhunter
28 Mar 2016 12:46Replace. You don't have the equipment required to test a coil.Oldercrow wrote: I have a 1979 kz750 and a 1976 kz400 and both are turning over, have gas, cleaned carbs but drive a bit weakly and then die. Seems like there could be a coil issue for both.
