kz750 / kz400 Coil bad? Replacement options?
  • Oldercrow
  • Oldercrow's Avatar Topic Author
28 Mar 2016 07:55
#717736
I have a 1979 kz750 and a 1976 kz400 and both are turning over, have gas, cleaned carbs but drive a bit weakly and then die. Seems like there could be a coil issue for both.
I saw a few videos on youtube showing how to test the ohm's on the coil. What is the best way to test the coils and deduce what's wrong?
Also, if I was going to replace the coils, would the Dyna 5 ohm coils Z1 sells be a good choice or should I go OEM?
www.z1enterprises.com/product/DYDC8-1-single
Thanks for any info!
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: kz750 / kz400 Coil bad? Replacement options?
28 Mar 2016 08:05
#717738
Dyna's are good coils. I have no complaints with mine. If you have points 5 OHM is OK.
  • loudhvx
  • loudhvx's Avatar
28 Mar 2016 08:06
#717739
The dyna 5 ohm is good if you for sure sticking with points. If you do, try to make sure the dwell angle is near the long end of the range... like 195 degrees. That means the points are closed a little more than half of a crank rotation.
Otherwise, there are 4-ohm options that look like the stock coils. I usually see them on ebay etc.
If you might go with electronic ignition in the future, then the Dyna 3 ohm may be a good choice in the interim. If you go with them, make sure the dwell is just a little under 180 degrees. That means the points are closed a tiny bit less than half of a crank rotation.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Mar 2016 08:10
#717741
I have 4 OHM. I can change lanes if I want to. :lol:
The following user(s) said Thank You: Oldercrow
  • Oldercrow
28 Mar 2016 08:20
#717746
Thanks for the reply!
Would those ebay 4ohm's be a good quick fix just to get running? Not doing a full restore at this point, just getting some bikes ready for new riders.
  • SWest
  • SWest's Avatar
  • 10 22 2014
28 Mar 2016 08:23
#717748
All I can say is you'll rule out one possibility. Coils get old and can fail in many ways.
  • loudhvx
  • loudhvx's Avatar
28 Mar 2016 09:51
#717768
Oldercrow wrote: Thanks for the reply!
It may be quick and cheap, but it may also be a permanent fix, for a few decades.
Make sure the listing says 4 ohms, or ask the seller. The 2.4 ohm coils look similar, but they will burn up the points.
They are the black ones that look like the stock coils (some of the stock coils were different color, though). The only issue is the mounting bolt spacing. If that's not listed, ask the seller. There are a few different spacings among Kz's, so you'll want to measure the old ones.
  • Oldercrow
28 Mar 2016 09:59
#717771
Can running a 5 ohm hurt anything?
  • bountyhunter
  • bountyhunter's Avatar
28 Mar 2016 12:39
#717792
Oldercrow wrote: Can running a 5 ohm hurt anything?
Won't hurt a thing.
  • bountyhunter
28 Mar 2016 12:45
#717793
Oldercrow wrote: I have a 1979 kz750 and a 1976 kz400 and both are turning over, have gas, cleaned carbs but drive a bit weakly and then die. Seems like there could be a coil issue for both.
Here is one that should work:
  • Oldercrow
28 Mar 2016 12:46
#717794
I got these from Z1 plus new wires.
  • bountyhunter
28 Mar 2016 12:46
#717795
Replace. You don't have the equipment required to test a coil.
