GPZ550 (1983) clutch help
Re: GPZ550 (1983) clutch help
18 Mar 2016 07:50
They kinda glue themselves together. Separating them and oiling them might do the trick.
- Channo
27 Mar 2016 19:53
Thanks for the suggestions. Just a quick update,:
Replaced clutch springs as new ones were available at my local dealer.
Changed oil to Castrol 4 T as recommended by a fellow GPZ owner
Soaked friction plates in the new oil for 3 days prior to installing
Adjusted the clutch mechanism ( clockwise, anticlockwise - who knows !!, this must be the most confusing adjustment ever in the history of motorcycles)
It's definetely better, when the engine/ oil is cold it's really good, once everything warms up it still grabs a bit but it's an improvement.
- Davidkz1r
28 Mar 2016 02:49
Just a small point, just check the clutch cable is the correct part number and not a cheap replacement the cable only needs to be a touch to long and you will not be able to pull it in completely even with full adjustment
- loudhvx
28 Mar 2016 08:01loudhvx wrote: Yes, it's hard to locate the correct procedure in the manual since you have to weed through the appendices, and the clymer is vague, and may be wrong.
gpzweb.s3-website-us-east-1.amazonaws.com/ClutchReleaseMech.GIF
Did you see this link? I have the same motor in one of my bikes, and the clutch adjustment is very simple once you know what's going on.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
