KZ750-P3 1983 shaftie
  • richardk
  • richardk's Avatar Topic Author
24 Feb 2016 00:24
#712253
hi all, bit of an odd one, can't seem to find the crank reference arrow that I've got to align my crank up with, it's the none points version and all the images I can find seem to be of the older points style.
or is just a case of finding tdc on 1/4 and then align the two cams up whilst at that and forget about any reference points, seems strange as there must be a mark to put a timing light on!! but I can't see one, must be going blind! does anyone have a picture of the mark??
thanks in advance
cheers
rich
  • wrenchmonkey
  • wrenchmonkey's Avatar
Re: KZ750-P3 1983 shaftie
24 Feb 2016 04:46
#712260
Hey Rich,
Well, I'm not totally sure if their the same but I just happened to photograph the ignition timing mark the other day.
Not sure exactly if this is what you were looking for or even if a 550a and 750p would be close?
So here it is:
You can just see the indicator hanging down into the open window. It looks rusty in this pic but in person I thought it was painted with like day-glow orange paint or something?
  • SWest
  • SWest's Avatar
  • 10 22 2014
24 Feb 2016 06:50
#712283
That's it. There should be a T mark on the advance plate for 2/3 too.
  • kawi810
  • kawi810's Avatar
24 Feb 2016 07:26
#712293
Attachment GPz750_BaseManual_Page_382.jpg not found
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
  • richardk
24 Feb 2016 23:39 - 24 Feb 2016 23:39
#712407
Argh, just had that moment of been a prick! Didn't see the supplement section in the manual!
Now I know why it won't start and spitting fuel back out the carbs!
Roll on the weekend and I get back home from working away!
Cheers everybody for the help
Rich
Last edit: 24 Feb 2016 23:39 by richardk.
