Valve gap still not in spec after shim swap
- blink543
18 Feb 2016 11:54
I was switching out the shims because alot of the valves literally had no gap at all. Keep in mind I swapped out the head because the other one was damaged. Not mechanically but physically. So anyways I followed the kz650 valve gap chart and it's still not in spec. They do have a gap now but not enough. They're like .06 or .07. Not the .08-.18 as specified. I mean obviously I would just have to go down another size but maybe I measured wrong or read the graph wrong.
Adam james
Re: Valve gap still not in spec after shim swap
18 Feb 2016 12:02
It's not unusual to have to move two shim sizes if the engine has been neglected. Hopefully the valves and seats are not permanently damaged from the neglect.
- strum
18 Feb 2016 12:31
If you had no gap then you had no idea how tight they were so all you can do is add something to give a gap which becomes your new start point.
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
18 Feb 2016 13:09
I had the same thing. I set them large. 500 miles later two had to be adjusted again.
- missionkz
18 Feb 2016 14:07 - 18 Feb 2016 14:09
This is the reason you should always have a very thin 2.00 to 2.20 shim in your parts bag so you can stick a KNOWN thin shim thickness in place of those that have zero gap.... measure the too wide of a gap with the thin shim, look at your chart, then decide what shim is needed to get the gap at around .002"-.004".
Really kinda Z1 "Engine Maintenance Tune Up" 101 in my honest opinion.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 18 Feb 2016 14:09 by missionkz.
- blink543
- blink543
19 Feb 2016 07:11missionkz wrote: This is the reason you should always have a very thin 2.00 to 2.20 shim in your parts bag so you can stick a KNOWN thin shim thickness in place of those that have zero gap.... measure the too wide of a gap with the thin shim, look at your chart, then decide what shim is needed to get the gap at around .002"-.004".
Isn't .002 or .004 too small of a gap though?
Adam james
19 Feb 2016 07:17
No, that's the low end.
- redhawk4
19 Feb 2016 07:41 - 19 Feb 2016 07:56
If you have zero gap, you don't know if the valve is closed and seated, therefore you can only guess a the size of the "minus gap" that exists in that situation. When you go to a thinner shim the amount you pick, it could, in theory, still leave you with no gap.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 19 Feb 2016 07:56 by redhawk4.
- blink543
19 Feb 2016 07:43swest wrote: No, that's the low end.
I'm measuring in mm though
Adam james
19 Feb 2016 07:47
Set them as per your manual.
- blink543
19 Feb 2016 07:51 - 19 Feb 2016 07:51swest wrote: Set them as per your manual.
Which is .08-.18MM
Adam james
Last edit: 19 Feb 2016 07:51 by blink543.
