- Thank you received: 2
Valve gap still not in spec after shim swap
- blink543
Adam james
- Thank you received: 2823
- strum
- Thank you received: 7
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
- Thank you received: 2749
- missionkz
Really kinda Z1 "Engine Maintenance Tune Up" 101 in my honest opinion.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
- blink543
- blink543
missionkz wrote: This is the reason you should always have a very thin 2.00 to 2.20 shim in your parts bag so you can stick a KNOWN thin shim thickness in place of those that have zero gap.... measure the too wide of a gap with the thin shim, look at your chart, then decide what shim is needed to get the gap at around .002"-.004".
Isn't .002 or .004 too small of a gap though?
Adam james
- redhawk4
- Thank you received: 64
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
- blink543
swest wrote: No, that's the low end.
I'm measuring in mm though
Adam james
- blink543
swest wrote: Set them as per your manual.
Which is .08-.18MM
Adam james
