exhaust crush gaskets
  • cafebrat
  • cafebrat's Avatar Topic Author
Re: exhaust crush gaskets
20 Feb 2016 12:01
#711658
My logic is that since they are soft crush gaskets, i could just tighten them slightly more than the last time they were on to crush themselves into making a new seal. We'll see what happens when i fire the bike in the spring.
83 Kawasaki Kz1100 LTD
81 Honda cm400
72 Suzuki T500 Titan** 2-stroke B)
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
20 Feb 2016 13:12 - 20 Feb 2016 13:15
#711667
The ones I referred to Ive had my pipes off 3 times and no leaks I just torque them back to spec. although they are a little thicker I like them worth the money
Last edit: 20 Feb 2016 13:15 by 9er rider.
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Feb 2016 13:21
#711669
I think I've reused mine for the last time. I'm getting popping and had a leak. Shimmed and tightened it but still a little popping. I'll order some soon.
  • rstnick
  • rstnick's Avatar
  • Premium Member
  • Premium Member
20 Feb 2016 13:42
#711674
I recall someone had a technique, where they heated the exhaust gaskets to red hot with a propane torch, then dropped them in cold water.
Not sure if that is the right procedure, but it did make them expand.
Rob
CANADA
2000 ZRX1100
2011 Ninja 250R - Wife's
2005 z750s
1978 KZ1000 project
1983 KZ1000R2
  • SWest
  • SWest's Avatar
  • 10 22 2014
20 Feb 2016 14:42
#711681
When I get my new ones, I'll have to try that with the old ones.
  • pete greek1
  • pete greek1's Avatar
21 Feb 2016 10:16
#711805
rstnick wrote: I recall someone had a technique, where they heated the exhaust gaskets to red hot with a propane torch, then dropped them in cold water.
I've also heard that about the copper head bolt washers
Pete
  • Casey H
  • Casey H's Avatar
21 Feb 2016 10:38 - 21 Feb 2016 14:26
#711809
Another option :)
Its expensive but the exhaust stay's on B)
You can't go back:)
Last edit: 21 Feb 2016 14:26 by Casey H.
  • Olajoe
  • Olajoe's Avatar
  • Free at last
21 Feb 2016 11:55
#711816
I think this thread might be receiving comments for different gaskets. Crushed vs flat. If it's flat I'll reuse those. Annealing the gasket may help, but from experience that's best done when new. Once the gasket is crushed, it becomes a formed in place gasket and re-alignment becomes even more critical.
