Clutch Screw Won't adjust/no clutch return
- kawasakisubaru
23 Jan 2016 17:41
So I took the sprocket cover off while I was checking for a leak, and then once I went to put the cover back on the clutch was completely out of place and the lever wouldn't return.
So i followed the steps in the workshop manual exactly as I should, and when i went to turn the adjustment screw "in until it tightens" it never tightened, and the cable never adjusted.
I also noticed the little single ball bearing that sits in the clutch mechanism on the cover is gone.
The clutch worked totally fine prior to my taking the cover off. I even adjusted the clutch about two months ago.
Any idea as to what could be causing this issue?
1980 KZ750 E1
Kerker by Kawasaki 4-1 exhaust
Lockhart oil cooler
Mikuni VM29 smoothbore carbs
Pingel high flow petcock
Dunlop K70s
Custom brat style seat
Clubman bars
Dime city cycles 1.5in tach/speedo
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- jertho
Re: Clutch Screw Won't adjust/no clutch return
23 Jan 2016 17:49
Are you sure the ball didn't fall out and roll away when you took the cover off? I would put another ball in and try it again.
Jerry
Jerry
1978 kz750 twin
- kawasakisubaru
23 Jan 2016 17:52
It did fall out. I noticed it was gone.
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
24 Jan 2016 07:53
Are you serious? You took things apart; a piece (the ball) fell out and is gone; and you cannot figure out what could be causing a problem? :blink: Have you considered selling your tools? :laugh: :laugh: :laugh: Ed
- kawasakisubaru
24 Jan 2016 08:18
I must have lost the ball LONG ago because the clutch worked fine for a long time until I took it apart again. Which is what confused me.
But I found a replacement bearing of similar size until my new one comes in
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- pete greek1
24 Jan 2016 08:28 - 24 Jan 2016 08:28
You couldn't have lost it LONG ago, your clutch wouldn't have worked without it, it's there for a reason
Pete
Pete
Last edit: 24 Jan 2016 08:28 by pete greek1.
- kawasakisubaru
24 Jan 2016 08:34
Maybe it was stolen by bearing gnomes while I wasn't looking.
Lol problem solved now anyways
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
- strum
24 Jan 2016 09:46kawasakisubaru wrote: Maybe it was stolen by bearing gnomes while I wasn't looking.
I sure hope you sober up before you ride :laugh: :laugh: :laugh: :laugh:
Blairsville Ga.
1980 KZ1000 Shaft (sold and missed already)
2003 ZRX 1200R (sold)
2003 Concours ZG1000 (just purchased)
- loudhvx
24 Jan 2016 12:06 - 24 Jan 2016 12:07
On the 550, the ball cannot come out through the sprocket side. It can only come out on the clutch side.
I thought the 750 was the same. Can anyone confirm? It may be impossible to lose the ball on the sprocket side.
More likely something has been messed up on the clutch actuator, which is on the sprocket cover.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Last edit: 24 Jan 2016 12:07 by loudhvx.
- KZB2 650
24 Jan 2016 12:34
Was thinking the same thing Loudhvx......looked it up on Partzilla and its the same as ours "behind" the push rod.........
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
- kawasakisubaru
24 Jan 2016 12:40
I have the 1980 750E and the bearing is on the outer side of the push rod. Inside of the sprocket cover. Despite what parts diagrams tell me...
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
24 Jan 2016 13:12 - 24 Jan 2016 13:14
If you have a 1980 KZ750-E engine and the ball is on the sprocket side someone has hosed it up and you need to correct it. If you do not, you will end up with a problem because the clutch push rod will come in contact with the clutch spring plate pusher which spins when you pull in the clutch lever while the engine is running. The ball bearing (#22 in the diagram below) prevents the rod from coming in direct contact with the spring plate pusher (#11). If the ball bearing is not there excessive friction and heat will result, and you will experience a problem. Ed
Attachment 00003g-4.jpg not found
Last edit: 24 Jan 2016 13:14 by 650ed.
