82 750 ltd case gasket?
- 82kzn73521
16 Jan 2016 12:28
Hello Everyone,
I have been looking for the gasket that goes between the 2 case halfs on my 82 750 ltd with no luck. I have been on ebay, partzilla and don't recal seeing one on z1enterprise but their site has been down since Christmas so I can't get back in to verify. Are there any other sources where I can find this elusive gasket? Thanks.
Re: 82 750 ltd case gasket?
16 Jan 2016 12:29
There isn't one. Use RTV or Three bond or the like to seal them
The following user(s) said Thank You: dom2570
- zukdave
16 Jan 2016 13:21
DO NOT USE RTV that shit has no place in a motor as far as concerned.
40 years working on engine's for a live want to guess how many stopped up oil pickup screen's I've seen ??
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- 82kzn73521
16 Jan 2016 14:14
So is there a suitable compound that you would recommend. The thought that is still in my head is why isn't there a gasket for those 2 halfs? Ayways. Thanks for the input.
- 82kzn73521
16 Jan 2016 14:21 - 16 Jan 2016 14:22
I use high temp copper silicon. Just enough to make it tacky. Yes, some use too much and clog all kinds of things. Even fill up thread holes and strip or break the cases. Form a gasket? BS.
Last edit: 16 Jan 2016 14:22 by SWest.
- zukdave
16 Jan 2016 14:3682kzn73521 wrote: So is there a suitable compound that you would recommend. .
Threebond or you can go to a dealer and get their brand Yamabond, Hondabond and I'm sure Suzuki has their's too.
My motor's put together with Hondabond because that's what we have at work but it's the same shit.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
16 Jan 2016 16:13 - 17 Jan 2016 03:57
Threebond comes in various types. The gray "liquid gasket" synthetic rubber material that most people associate with Threebond, and Yamabond, Kawabond, Suzukibond, and Hondabond, comes in various formula's. Kawasaki sells TB 1105B through the dealerships but TB 1184 is the most recent aftermarket derivative.
TB 1207B is also commonly used to seal cases and is an RTV product. This material is black so it doesn't mess up the appearance of black engines. My 750E had this stuff applied from the factory when I tore down the engine. Some people bash the use of RTV but Kawasaki used the stuff (and so did I when reassembling the engine).
Last edit: 17 Jan 2016 03:57 by Nessism.
16 Jan 2016 21:43
Or you could go to a local auto parts store and buy a sheet of gasket material near the same thickness as the factory version and use an Exacto knife to make your own.
- kawi810
17 Jan 2016 01:18
i use Threebond 1211 .works great .no gasket between case halves.
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
17 Jan 2016 04:01kawi810 wrote: i use Threebond 1211 .works great .no gasket between case halves.
The Threebond 12XX family of products is RTV.
- 82kzn73521
19 Jan 2016 08:13
Thanks everyone for your input. It is much appreciated and definitely saved me time and sanity looking for something thats not available. You guys are great.
