82 750 ltd case gasket?
- 82kzn73521
Re: 82 750 ltd case gasket?
27 Jan 2016 05:49
I know this is off topic (kind of) but the seals that go on the crankshft I am only finding for one side. The other is showing discontinued. Are they the same because they look that way. Thanks in advance.
27 Jan 2016 06:55
Those seals have a spiral flute going in opposite directions depending on the side, theoretically working oil back into the engine based on direction of rotation. In reality, I think you would be fine to use the same seal on both sides. Another option is to purchase an aftermarket seal kit which has directional seals.
82kzn73521 wrote: I know this is off topic (kind of) but the seals that go on the crankshft I am only finding for one side. The other is showing discontinued. Are they the same because they look that way. Thanks in advance.
- 82kzn73521
27 Jan 2016 07:55
That's what I was thinking. I read ,somewhere on here I think, of someone with the same problem doing that and not having any problems.Thanks again.
