82 750 ltd case gasket?
- 82kzn73521
I have been looking for the gasket that goes between the 2 case halfs on my 82 750 ltd with no luck. I have been on ebay, partzilla and don't recal seeing one on z1enterprise but their site has been down since Christmas so I can't get back in to verify. Are there any other sources where I can find this elusive gasket? Thanks.
- Thank you received: 2749
- zukdave
- Thank you received: 229
40 years working on engine's for a live want to guess how many stopped up oil pickup screen's I've seen ??
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- 82kzn73521
- 82kzn73521
- zukdave
82kzn73521 wrote: So is there a suitable compound that you would recommend. .
Threebond or you can go to a dealer and get their brand Yamabond, Hondabond and I'm sure Suzuki has their's too.
My motor's put together with Hondabond because that's what we have at work but it's the same shit.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
- Thank you received: 2823
TB 1207B is also commonly used to seal cases and is an RTV product. This material is black so it doesn't mess up the appearance of black engines. My 750E had this stuff applied from the factory when I tore down the engine. Some people bash the use of RTV but Kawasaki used the stuff (and so did I when reassembling the engine).
- Thank you received: 2234
- kawi810
- Thank you received: 11
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
kawi810 wrote: i use Threebond 1211 .works great .no gasket between case halves.
The Threebond 12XX family of products is RTV.
- 82kzn73521
