kz1100 top end rebuild
Re: kz1100 top end rebuild
10 Jan 2016 17:02In the last 2 rebuilds over the last 10 years I have had perfect luck with Cometic Gaskets and my motor is subjected to over twice the power yours will be.cafebrat wrote: With a couple of you mentioning gasket quality, can anyone vouch for vesrah gaskets? I found a top end kit that has everything all in one, including valve seals
But I am just one voice here
- cafebrat
11 Jan 2016 06:49
I've begun to track down and tally up all the parts ill need to replace in the top end and whoaaah did it add up quick. Close to $600 so far. So Im currently trying to find some OEM gaskets on ebay as oppose to paying $45 a piece for head gaskets (2)!. Anyways, this may be a stupid question, but since my #1 and #4 cylinder compression was near perfect, instead of ordering 4 sets of rings at $50 a set, can i just replace the #2 & #3? Sorry if thats a stupid question but ive just always replaced all rings anytime i do the top end on a bike, and didnt know if there was any reason you couldnt do just the lower compression cylinders. Thanks in advance.
83 Kawasaki Kz1100 LTD
81 Honda cm400
72 Suzuki T500 Titan** 2-stroke
81 Honda cm400
11 Jan 2016 07:05 - 11 Jan 2016 07:06
Replace them all. Could have been valves or sticky rings. You won't regret it. Pics? Check out my good guys thread for gaskets.
Last edit: 11 Jan 2016 07:06 by SWest.
- cafebrat
11 Jan 2016 07:23
Thanks steve,
Guess ill just bite the bullet and buy 4 new sets.
Also just for anyone else with a LTD L1 model, they take different rings than all other 1100 models. All others take part# 13008-5037 which can be found plenty of places, but the LTD model calls for part# 13008-5055 which ive only found a few places. Just note worthy for anyone with an LTD.
What would you like pics of steve?
81 Honda cm400
81 Honda cm400
11 Jan 2016 07:26
with those compression numbers i wouldn't be messing with the rings..
you can replace the 2 piece head gasket with a one piece one.
- pete greek1
11 Jan 2016 08:24
No eBay APP ID and/or Cert ID defined in Kunena configurationI don't know if this Cometic head gasket fits your needs, but it's reasonably priced
if not, you can contact the seller & see if he has what you need
Pete
Pete
11 Jan 2016 11:58
Pics of the cylinders, valves, plugs etc.
12 Jan 2016 04:05
No eBay APP ID and/or Cert ID defined in Kunena configurationfrom pete greeks link
- cafebrat
15 Jan 2016 10:07
I just dropped off my cylinders, cylinder head and valve cover off to a guy i met on another forum to have them all vapor blasted. Ill upload pics of everything before and after. Also, any recommendations on what type of honing tool gives the best results. Im just deglazing more than anything.
81 Honda cm400
81 Honda cm400
