Air passages from head to reed valve assembly
  • Madtrout
  • Madtrout's Avatar Topic Author
22 Dec 2015 05:18 - 22 Dec 2015 05:35
#703964
Greetings all. I have just removed the head from my 1982 GPZ750 with 87,000 miles for its first ever top end rebuild. I noticed the passages from the head to the reed valve assembly is clogged on both sides. I can't tell if this is some kind of rubber plug that has degraded or just cooked and clogged oil. If anyone knows whether this should be cleaned up please let me know. All the best, Mark
Attachment Passagewayscopy.jpg not found
Last edit: 22 Dec 2015 05:35 by Madtrout.
  • floivanus
  • floivanus's Avatar
Re: Air passages from head to reed valve assembly
22 Dec 2015 05:27
#703966
It's most likely carbon build-up, if you are adamant about getting the fresh air system working clean them out, if not it really wont affect anything, many people just block them off
Past; 78 kz1000, 83 kz550
Andrew
  • SWest
  • SWest's Avatar
  • 10 22 2014
22 Dec 2015 05:30
#703967
Welcome. Looks like a head refresh is timely. Pics more pics. :cheer:
  • redhawk4
  • redhawk4's Avatar
22 Dec 2015 07:05 - 22 Dec 2015 07:06
#703971
I'd be more worried about the amount of black carbon build up overall. It looks like either someone didn't change the oil very often, or the engine is worn putting a lot of deposits in the oil, or both..
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
Last edit: 22 Dec 2015 07:06 by redhawk4.
  • Nessism
  • Nessism's Avatar
22 Dec 2015 07:59
#703973
It's carbon build up. Perfectly normal for a bike with that many miles on it.
When rebuilding my 750 I tapped the holes and installed metal plugs. If you just want to restore the bike back to stock just clean out the carbon during the head refurbishment process. No big deal.
The following user(s) said Thank You: Madtrout
  • redhawk4
  • redhawk4's Avatar
22 Dec 2015 09:15 - 22 Dec 2015 09:17
#703984
Nessism wrote: It's carbon build up. Perfectly normal for a bike with that many miles on it.
Oops I missed the 87k miles in the original post, yes that would be normal, particularly given some wear starts to be inevitable adding to the carbon build up. It's impressive the miles these Kawasaki's are capable of when only a few years before many other bikes needed attention by 12k miles.
1977 KZ650B1
1980 Suzuki SP400
Last edit: 22 Dec 2015 09:17 by redhawk4.
