Oil leak from valve cover - valve adjustments
- redhawk4
Re: Oil leak from valve cover - valve adjustments
15 Nov 2015 13:14 - 15 Nov 2015 13:22Z1Driver wrote: I have to agree if some goof ball told me my valve cover gasket was leaking because the valve tolerances were off, I would never step inside that shop again. Period. Like already stated, valves have nothing to do with valve cover gaskets. If the shop did the work, they need to fix the leak. But with the answer you received I would run far far away from the idiot.
The guy would either have to be an utter fool to say that or be completely dishonest and looking to screw you over by claiming to do unnecessary work - either way give him a wide berth.
My recently acquired KZ1000 had the tiniest of leaks at the valve cover when I bought it, the engine had been apart for a big bore kit less than a 1,000 miles earlier. I checked the bolts and most were barely more than finger tight. I tightened them correctly and no sign of a leak since. I'm not 100% familiar with the KZ750, but a lot of leaks occur round the end plugs used where the cams are through bored, the rubber shrinks with age and is no longer compressed adequately between the valve cover and the head. When you say they put gasket sealer on the ends, are you meaning where these end plugs are? it's quite common to use a bit of gasket sealer there to take up the gap left by shrinkage. I would first check every thing is torqued down correctly on the valve cover, then if it still leaks go from there. If they used a new gasket when the engine work was done. it may just be a little loose.
1978 KZ1000A2 Wiseco 1075 kit
1977 KZ650B1
1973 Triumph Tiger TR7V
1968 BSA Victor Special 441
2015 Triumph Thunderbird LT
1980 Suzuki SP400
Old enough to know better, still too young to care
1977 KZ650B1
1980 Suzuki SP400
Last edit: 15 Nov 2015 13:22 by redhawk4.
- ThatGPzGuy
16 Nov 2015 00:46Z1Driver wrote: I have to agree if some goof ball told me my valve cover gasket was leaking because the valve tolerances were off, I would never step inside that shop again. Period. Like already stated, valves have nothing to do with valve cover gaskets. If the shop did the work, they need to fix the leak. But with the answer you received I would run far far away from the idiot.
Hard to believe a mechanic would say something that stupid. Perhaps he was suggesting the valves should be checked as long as the valve cover was going to be coming off anyway?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- redhawk4
16 Nov 2015 05:10 - 16 Nov 2015 05:10ThatGPzGuy wrote:Z1Driver wrote: I have to agree if some goof ball told me my valve cover gasket was leaking because the valve tolerances were off, I would never step inside that shop again. Period. Like already stated, valves have nothing to do with valve cover gaskets. If the shop did the work, they need to fix the leak. But with the answer you received I would run far far away from the idiot.
He's talking rubbish, obviously the tire pressures being too low is causing the oil leak
1977 KZ650B1
1980 Suzuki SP400
1977 KZ650B1
1980 Suzuki SP400
Last edit: 16 Nov 2015 05:10 by redhawk4.
- kawasakisubaru
25 Dec 2015 11:25
Update:
So I finally got the valve cover off, and the valve clearances were fine (no surprise there as my clearances were set less than a year ago).
But the shop that did my rebuild put gasket sealant all over the valve cover gasket.
I scraped off as much of the gasket that was stuck to the engine as i could, taking care to not dig too deep.
Do any of you guys recommend any specific products or way to go about smoothing, cleaning, preping, and sealing (where they may be abrasions) the new gasket?
I have a set of cam end caps and a tutorial I found on a KZ1000 to help me set the caps.
1980 KZ750 E1
Kerker by Kawasaki 4-1 exhaust
Lockhart oil cooler
Mikuni VM29 smoothbore carbs
Pingel high flow petcock
Dunlop K70s
Custom brat style seat
Clubman bars
Dime city cycles 1.5in tach/speedo
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
25 Dec 2015 13:05 - 25 Dec 2015 13:06
I use High Temp Silicon for the end plugs. There are some plastic abrasive wheels that do a good job of taking off old gaskets. Sounds like they used Permatex. If that's what he used, he is a moron. High Temp Silicon will work and can be removed easily.
Last edit: 25 Dec 2015 13:06 by SWest.
- kawasakisubaru
25 Dec 2015 13:17
That crusty brown caked on stuff i was scraping off is permatex I'm pretty sure...
1980 KZ750 E1
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
Lockhart oil cooler
Dunlop K70s
Clubman bars
Ox blood grips
25 Dec 2015 13:25
I learned about that crap when I was 18. Non hardening my a$$.
