Color tune
- ThatGPzGuy
Re: Color tune
16 Oct 2015 01:35
Where is the sensor installed? In the crossover pipe?
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
Re: Color tune
16 Oct 2015 02:11
Here is a previous discussion of O2 sensors with some links to earlier ones.
www.kzrider.com/forum/2-engine/591815-na...band-fuel-air#612713
- KZB2 650
Re: Color tune
16 Oct 2015 05:34 - 16 Oct 2015 05:51ThatGPzGuy wrote: Where is the sensor installed? In the crossover pipe?
I see where it is installed in TexasKZ's link but is there a fitting that needs to welded in then this screws on or will it just screw into a drilled and tapped hole? And can it be installed on the inside so its hidden ?
Bought a color tune that I hav'nt used yet and you guys got me thinkin on this.
I see in the Apsx add it has a nut so I guess you just drill a hole and connect it this way...... problem with that is my collector has been on for 32 years and I could not even budge it a few years back. :pinch:
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 16 Oct 2015 05:51 by KZB2 650.
- jackleberry
Re: Color tune
16 Oct 2015 07:17 - 16 Oct 2015 07:20ThatGPzGuy wrote: Where is the sensor installed? In the crossover pipe?
I haven't decided that. Personally, I was just going to shove the sensor in the tailpipe. The AFM is only needed to tune things up---I'm not sure I'd want to install it permanently.
To get the best results with tuning idle mixtures, you'd want to be able to do one cylinder at a time--and that would require installing
bungs in each header.
[strike]On the other hand, on a bike with a 4 into 2 exhaust, it seems that by unplugging cylinders 2 & 3, you could tune #1 by sticking the sensor in the left tail pipe and then #4 by sticking it in the right. Then plug 2 & 3 back in and unplug 1 & 4 and repeat for tuning 2 & 3. May sound like a hassle, but that's really no worse than all the fiddling with the colortune (assuming you only buy one and not a set of 4 which would be crazy expensive).[/strike]
(EDIT: nevermind... not enough coffee. the disabled cylinders would screw up the reading)
Tuning jets could be one with an overall reading. So yeah, I think installing in the crossover would be good for that.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
2001 KZ1000P (P20)
Last edit: 16 Oct 2015 07:20 by jackleberry.
- zukdave
Re: Color tune
16 Oct 2015 17:19
The cross over tube will not have enough exhaust flow to work right.
A wide band with one 02 sensor will only work in a 4 to 1 exhaust system
and the sensor needs to be installed in the collector so it reads all 4 cylinders.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
Re: Color tune
16 Oct 2015 17:29
On my bike the 2:00 position would be pointing inside the frame. Good place for it but I can't see spending the money.
- Old Man Rock
Re: Color tune
18 Oct 2015 04:16
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
- Old Man Rock
Re: Color tune
18 Oct 2015 04:21 - 18 Oct 2015 04:25
As for the color tune....
Video of operation I did years ago on my KZ900....
Crank up the volume where you can hear by adjusting your carb the RPM response...
Operation & Tunning Steps Chart:
Attachment ColorTuneChartnSteps.jpg not found
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 18 Oct 2015 04:25 by Old Man Rock.
Re: Color tune
18 Oct 2015 04:42 - 18 Oct 2015 04:43
OMR, it's too blurry to read. Could you send me your charts PDF by e-mail? It's in my profile.
Thanks
Thanks
Last edit: 18 Oct 2015 04:43 by SWest.
- 9er rider
- Keep a cool tool
Re: Color tune
18 Oct 2015 06:45
yea lets see those
- ThatGPzGuy
Re: Color tune
18 Oct 2015 06:55
It's on their website
Gunson Colortune
I have had good results with mine.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
- Old Man Rock
Re: Color tune
18 Oct 2015 11:26
chart 1:
www.carbtune.co.uk/Images/Colour%20Chart%201.jpg
CHart2:
www.carbtune.co.uk/Images/Colour%20Chart%202.jpg
Chart3:
www.carbtune.co.uk/Images/Colour%20Chart%203.jpg
CHart2:
Chart3:
1976 KZ900-A4
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
