- Thank you received: 27
Kz750h winter tune ups.
- dom2570
I did a few searches online and found a few different options, so I decided to check in with you guys before I buy anything. When it comes to gaskets, Is there any particular brand I should be looking for, and are there brands I should stay far away from?
Thanks
Whip it like a mule!
- Thank you received: 2823
- dom2570
dom2570 wrote: Ok, I've checked out that head gasket on flebay a few times. It just looked a little odd to me
Kawasaki revised the head gasket a bunch of times over the years. That one with the red stuff on it is basically same as your original head gasket only Kawasaki added red RTV on it to help improve the oil tightness. I bought one of those gaskets and installed it on my engine a couple weeks ago. No experience beyond that but as long as you purchase a real Kawasaki gasket, you should be fine.
One thing I learned when shopping for gaskets is that Kawasaki merged the 650 gaskets together with the 750 gaskets, with the 750 being the default. The bore hole size is bigger, which apparently works just fine with the smaller engine. I'm not sure what would happen if you purchased a 650 gasket, with the smaller bore hole, and installed it on a later 750. My guess is it wouldn't hurt anything, but I made the effort to purchase the larger gasket just to be safe.
- Thank you received: 2749
- dom2570
- dom2570
- zukdave
- Thank you received: 229
plus you then can use a socket to remove it.
Find a nut that will slide over the stud slide it to the head and mark the stud flush with nut the
remove nut and cut the stud between the mark and head put the nut over the stud and fill the
hole with weld let cool a few min. and the stud will come right out.
As for the plug hole don't waist time chasing or a helicoil use a timesert
helicoils are not ment for a thread that will see a lot of remove/replace of the bolt
like a plug will.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
- dom2570
It came right out didn't damage the threads at all! I had a blow torch ready, but didn't need it.
Now, the only scary thing left to do is the spark plug hole. Then it is just cleaning, cleaning, and more cleaning![IMG][/img]
