KZ1000P Valve adjustment
  • ThatGPzGuy
  • ThatGPzGuy's Avatar Topic Author
03 Oct 2015 11:41
#693160
Hey Gang, doing the right thing and checking the valves on my '01 KZP.
What a PITA. I have the Motion Pro Tool and I am able to get to the 1 and 4 intake and exhaust valves. The Inside ones are pretty tough.
I also noticed this:
[IMG
Looks like the cam bearing has slipped to the right? Or is this normal?
If I have to repair this I might as well pull the cams. At least is would be easier to check the shims...
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • jackleberry
  • jackleberry's Avatar
Re: KZ1000P Valve adjustment
03 Oct 2015 12:33
#693172
:sick:
ThatGPzGuy wrote: Hey Gang, doing the right thing and checking the valves on my '01 KZP.
[IMG
That's not normal. You need to fix it. Hopefully the bearing isn't damaged. Yeah that motion pro tool is a joke. I just take off the cam caps. If you zip tie the camchain to the camshaft sprockets you can do it without messing up the cam timing. Taker it slow and be careful, those bolts are easy to strip. Don't torque them any tighter than 80 inch/lbs.
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Oct 2015 12:39
#693174
At least take off that one cap. Is it turned around? There's a cut out that keeps this from happening. I'm buying the factory style tool. Too easy to strip out the threads. :unsure:
I salute you for doing this sir. ;)
  • ThatGPzGuy
03 Oct 2015 15:25
#693201
It looks like it just shifted to the right.
[IMG
I don't see any damage to the journal:
[IMG
Weird. I don't know how this can happen unless it was installed that way.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Oct 2015 15:40
#693204
It happens. Make sure there is no oil under it. You can see how it shifted.
  • ThatGPzGuy
03 Oct 2015 16:00
#693206
On the valves. Four were too tight (2 ex and 2 in) and the other four were within spec.
Should run much better when I am done.
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
03 Oct 2015 16:39
#693212
ThatGPzGuy wrote: On the valves. Four were too tight (2 ex and 2 in) and the other four were within spec.
Finished with mine two days ago, and had one shim thickness change (250 to 255), on one exhaust valve. The rest were great after 5000 miles. I am amazed at the significant improvement in engine performance and smoothness after such a small change like this, and the carb (re)sync that followed. :)
1982 KZ1100-A2/1170 sleeper 😀
  • jackleberry
03 Oct 2015 18:24
#693226
And now you can see why everybody recommends doing the valves before dicking with the carbs ;)
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • jackleberry
03 Oct 2015 18:25
#693227
So what did you do to lock that bearing back in place? In the picture, it does look like it has worn unevenly due to having shifted...
1997 KZ1000P (P16)
2001 KZ1000P (P20)
  • SWest
  • SWest's Avatar
  • 10 22 2014
03 Oct 2015 18:37
#693230
The proper way would have been plasti gauge. I would have taken a punch to the boss in two places so it wouldn't shift again. I didn't suggest it because it could have caused more harm than good if done wrong.
  • ThatGPzGuy
04 Oct 2015 06:22
#693263
I have not done anything yet. What would you recommend? Replace them all?
Jim
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • daveo
  • daveo's Avatar
  • Premium Member
  • Premium Member
04 Oct 2015 08:34
#693274
Not that I'm any kind of expert, or may have worthy advice to take...but I would just replace that pair of bearings and leave it at that.
It doesn't appear that the cam bearing journal was damaged at all, but if that bearing were slightly further over, we'd be discussing where to get a good motor. My guess is that it was an assembly mistake, and has not shifted since...how would or could it? :unsure:
