Valve shim gaps -All equal or not?
- missionkz
Re: Valve shim gaps -All equal or not?
20 Sep 2015 07:11 - 20 Sep 2015 07:12
Oh brother.... I just talked to a buddy who is a big shot Mazda mechanic at the dealership and he said many DOHC and SOHC engines, with direct cam over valve, will see an increase of lash with a hot engine over cold... man have I been doing this wrong for the last 43 years?
Or, just following the FSM and using 0.05mm to .010mm "COLD" ....takes all this into consideration and screw the rest of this chatter?
CRAP!!
CRAP!!
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
Last edit: 20 Sep 2015 07:12 by missionkz.
- scubaanders
20 Sep 2015 08:09
missionkz wrote:
Must say that, that rocks my world, but I am open for new views.
So running an engine with less than 0,05 is no big deal, the thermal expansion of Al (22) will save my day and exhaust valves.
Gpz750R1 1982
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
Gpz750A1 1983
Gpz1100A2 1984
FZ750 1985
Gpz900R -91
- 80B4
20 Sep 2015 09:05
Nissan lists both the cold and hot valve clearance specs for the Altima 2.5 L engine. The hot spec is larger than the cold spec by .004 in.
Tight valves make for hard starting and poor idle so running with less than .05 is a big deal. Set your valves tight and let us know how it works.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
- zed1015
20 Sep 2015 09:05 - 20 Sep 2015 09:08
Every engine design is different depending on specification and the materials used .
You cannot use the old OHC vs pushrod valve train expansion rate comparison pulled off some automotive engineering website as a blanket statement.
It may be typical but it is NOT applicable to every OHC design.
On these particular KZ engines the valve clearance reduces with heat.
I have measured this many times in my 35 years of KZ riding, tuning and racing .
The thermal expansion of the exhaust valves exceeds that of the head greatly and the intakes less so due to intake charge cooling but it's still slightly more than the head material.
The intakes expand almost in line with the head whilst the exhausts close up dramatically.
You are all welcome to go thrash your KZ's with 0.05mm valve clearances if you like but don't come back moaning when you have burnt exhaust valves and a large mechanics bill to pay.
Last edit: 20 Sep 2015 09:08 by zed1015.
- kawi810
20 Sep 2015 10:05
on the Megacycle cam website this is what they list for valve lash for 650/750 engines
NUMBER LIFT AT .040" CENTERS DESCRIPTION AND APPLICATION EXHAUST OPEN/CLOSE CLEARANCE
471-00 .354" 254° 110° OK with stock pistons and springs. Mild increase 17 btc/57 abc .004"
.354" 254° 110° in power from 3800 to 7500. Good mid-range. 57 bbc/17 atc .004"
471-70 .380" 256° 105° All around street/road performance cam. Wide 23 btc/53 abc .004"
.380" 261° 108.5° smooth power band. GPZ-750 OK with stock 59 bbc/22 atc .004"
pistons and springs. All other models require
modified pistons and springs.
471-10 .410" 250° 105° Use racing pistons & springs. Road race/drag race. 20 btc/50 abc .006"
.410" 250° 105° Great throttle control. Mid-range and top-end. 50 bbc/20 atc .006"
Great for ¼ and ½ mile mini sprint
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
- kawi810
20 Sep 2015 10:10
for the 900/1000 it is even more at .006-.007 thous.the higher the horsepower, the more heat is created, the more the valve expands.
- loudhvx
20 Sep 2015 16:26
Aluminum expands more than steel, but the valve is hotter than the overall head. It could theoretically go either way depending on the details of construction and materials.
On the 550's the gap gets smaller as it heats up. Several 650 guys reported that their gaps got bigger as it heats up.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
20 Sep 2015 16:33
If I had under bucket shims and a radical cam set up, I might go .006-7. With shim on top, I'll stick with .002-4. :whistle:
