Cyl 1 fouling out, where to start...?
- Turbo99397
13 Sep 2015 12:38 #689897
by Turbo99397
Cyl 1 fouling out, where to start...? was created by Turbo99397
1980 kz1000, I got my 2-3 cyl issue taken care of, was bad pickup coil... I noticed at lower rpm and idle it sounds like a cyl is missing out. After riding in pulled it into the garage and cyl 234 are abt 485 degrees on the header right from the head, and cyl 1 is at abt 287 degrees, if I Rev it up to abt 3k for 10 sec or so the other cyls will hit abt 625 degrees and number one will be at abt 385 degrees, when I pulled the plug it was wet and black. Put clean plug in and seemed ok for a bit. Seems all there at high rpm, or at least I think it is.... also have accel coils and stock wires with the resistance caps, should I run new wires? What's a good plug to run that will spark in many conditions and not foul out... if I pull the wire it seems to run the same.
- Irish Yobbo
- Thank you received: 93
13 Sep 2015 13:48 #689904
by Irish Yobbo
1981 KZ750 LTD
Replied by Irish Yobbo on topic Cyl 1 fouling out, where to start...?
Wet and black most likely means that cylinder 1 is running rich - might need to have a play with your cylinder 1 carb. It's almost definitely a fuelling issue.
1981 KZ750 LTD
- Turbo99397
13 Sep 2015 14:00 #689906
by Turbo99397
Replied by Turbo99397 on topic Cyl 1 fouling out, where to start...?
I have mower petcock in line with thhe fuel line if I forget to shut it off I'll have fuel pouring everywhere... I'd assume needle and seat would close and fuel wouldn't be pouring out if it's running right... what things to I need to look for if I pull carbs off???
- Thank you received: 2234
13 Sep 2015 14:04 #689908
by TexasKZ
Replied by TexasKZ on topic Cyl 1 fouling out, where to start...?
The best plugs to use are either NGK or ND in the heat range recommended by Kawasaki. It is not a good idea to try to mask another problems by using some non-standard plugs.
If the routine maintenance has been done in accordance with the fsm, then what you describe could well be caused by a sticking float valve. If the maintenance items, especially valve clearance and fuel level, have not been done, do them before trying other solutions.
13 Sep 2015 14:07 - 13 Sep 2015 14:07 #689910
by TexasKZ
If you have fuel running out of the carburetor, then the fuel level is too high, the float valve is not closing, or the overflow tube is broken.
Or all the above.
Or all the above.
Last edit: 13 Sep 2015 14:07 by TexasKZ.
13 Sep 2015 14:09 #689911
by TexasKZ
Why are you using a mower petcock??
- Turbo99397
13 Sep 2015 14:13 #689912
by Turbo99397
I bought it this way, has original petcock but owner said they tend to leak so I have another one in line before carbs. I just shut that one off. Do I set float level with carbs upside down? And do I measure from where the bowl cover goes on?
- Turbo99397
13 Sep 2015 15:19 #689917
by Turbo99397
Just changed the oil... some fuel smell to it prob from when 2-3 weren't firing... put back in stock ngk plugs rode it pretty hard abt 15 mins and seemed to be ok.., can tell there's minor tuning to be done, prob needs valve adjustments but all cylinders were at abt 500 degrees when I got back so they were all firing right now. I hate carbs.
13 Sep 2015 15:49 #689923
by TexasKZ
Most folks around here use the factory petcock. Kawasaki and K&L make high quality rebuild kits for them.
The fuel level is set using the clear tube method, without removing the carburetors. It is clearly described in the factory service manual and in about a hundred threads on this site.
If the valves are significantly out of adjustment, it will be impossible to properly adjust the carburetors.
A leaking carburetor will almost always leak fuel into the crankcase. Diluted oil will not lubricate properly, and sometimes gasoline can completely fill the crankcase with catastrophic results.
Just picking random things to fix rather than following the procedures outlined in the factory service manual, especially on a motorcycle that you do not know the service history of, more often than not will lead to frustration.
- Turbo99397
13 Sep 2015 16:04 #689926
by Turbo99397
Agreed.. so I can only measure float level with clear tube no? Is that just measuring the height? Also seems my kick starter not working.. is there another way to turn over motor to adjust valves? Guessing valve adjustment going to be my next procedure to do.
13 Sep 2015 16:19 #689930
by TexasKZ
Float height is irrelevant. the actual fuel level is very important, and the clear tube method is the way to do it.
To turn the engine during valve adjustment, use the 17mm not on the right end of the crankshaft. DO NOT USE THE 13mm NUT.
PLEASE get a factory service manual before you tear into the engine. It will save you far more money than it costs.
- Thank you received: 2749
13 Sep 2015 17:02 #689933
by SWest
Replied by SWest on topic Cyl 1 fouling out, where to start...?
Yes, you need a manual.
