Engine slapping noise
  • Drafter89
  • Drafter89's Avatar Topic Author
26 Aug 2015 05:39
#687159
Working with a 78 400. I know this is nearly impossible to diagnose over the internet but maybe I can get pointed in the right direction. Loud knocking, more like a slapping noise sounds like its coming from my top end. It only happens when the engine is hot and when I give it throttle. Valve clearances are to spec. Took the head off last night and the top of the two intake valves look like they have taken a slight beating. the exhaust valves look ok. My right piston has a tad bit of play in the bore but I think thats normal. I dont know where to start really. Could this be a rod or bearing problem? A while back I drained the oil on this thing and It had some shiny bits in the filter. Any help?
Thanks
78 KZ 400 C1-Daily Driver
New Albany,IN
  • Drafter89
Re: Engine slapping noise
26 Aug 2015 05:47
#687161
The manual sais it could be a stuck valve in the valve guide or something so I guess I can start there and see if that does anything.
New Albany,IN
  • Tyrell Corp
  • Tyrell Corp's Avatar
26 Aug 2015 06:59 - 26 Aug 2015 07:01
#687169
That is a bad omen. I don't think sticky valves are the problem, a compression test and intake vacuum check would diagnose this further.
Piston slap would usually be worst when cold as the ally pistons expand...(a lot of new cars are bad for this as they use low friction slipper pistons with thin rings)
More noise when motor is loaded I'm thinking bottom end bearings, usually knock more than a slap. When i took main bearings out on a car it felt like driving over marbles, it died fast within a few miles, conveniently around the corner from a scrapyard.
Last edit: 26 Aug 2015 07:01 by Tyrell Corp.
  • SWest
  • SWest's Avatar
  • 10 22 2014
26 Aug 2015 07:14
#687171
The more you run it, the worse it's going to be.
steve
  • Drafter89
26 Aug 2015 09:45
#687182
:angry: :angry: :angry: This is my only running bike :( I need something to ride!!! Oh well, Ill practice on that scrap motor first before I start this one
New Albany,IN
  • pete greek1
  • pete greek1's Avatar
26 Aug 2015 10:13
#687184
Did you check your cam chain tension ? a loose cam chain can make a slapping sound
Pete
  • Tyrell Corp
26 Aug 2015 10:13 - 26 Aug 2015 10:22
#687185
Just re-read you original post, was the valve timing marks and top run links count correct when you took it apart? You might be needing the 'scrap' engine for parts here. Pics would be good.
Pete
Loose camchains have a sort of 'bunch of keys' tinkle, more than a slap, most apparent at about 4k on the 550's. Definitely worth checking though, it is a bit difficult diagnosing this remotely.
Last edit: 26 Aug 2015 10:22 by Tyrell Corp.
  • Drafter89
26 Aug 2015 13:12
#687219
pete greek1 wrote: Did you check your cam chain tension ? a loose cam chain can make a slapping sound
Pete
Yep. Had to adjust it. Statrted it up and took it for a ride but noise was still there...And its a loud knock so It isnt the tension
New Albany,IN
  • Drafter89
26 Aug 2015 13:17
#687220
Tyrell Corp wrote: Took the head off last night and the top of the two intake valves look like they have taken a slight beating.
Everything was correct to my knowledge...I do everything by the book. I can get pics. What would you like pics of?
New Albany,IN
  • Tyrell Corp
26 Aug 2015 14:34 - 26 Aug 2015 14:36
#687225
Just interested in the inlet valves, this 'taken a slight beating' comment...do you think there has been piston/valve contact? Generally these motors have quite generous clearances when stock, hence they take quite a lot of abuse.
If the big end end bearing(s) is/are badly stuffed, you'll know as soon as you get the block off.
If the right hand bore has more clearance than the other, that could be a problem. Was the bore scored or any visible damage? Was it smoking at all? Check out my 'thar she blows' 550 thread, i had something similar...top end rattle and finally belching white smoke - it got much worse within a few hundred miles.
Last edit: 26 Aug 2015 14:36 by Tyrell Corp.
  • Drafter89
26 Aug 2015 17:55
#687249
Bad lighting but best I could do. Bores are smooth , no scoring at all, but the right piston is scored pretty bad in that one spot as you can see. That's the only thing wrong with them. And the rod on the right cylinder has a ton of up and down play. Left one won't even budge. The build up on the valves is normal I believe. And that's about as far as I've gotten.
New Albany,IN
  • Drafter89
26 Aug 2015 18:00
#687250
Tyrell Corp wrote:
If the right hand bore has more clearance than the other, that could be a problem. Was the bore scored or any visible damage? Was it smoking at all? .
Posted some pics. And this thing hasn't smoked one bit.
New Albany,IN
