Engine slapping noise
Re: Engine slapping noise
30 Aug 2015 16:01
Twisted crank?
- Drafter89
30 Aug 2015 16:08 - 30 Aug 2015 16:12TexasKZ wrote: Twisted crank?
I just read where somebody had that problem. Can it be fixed? How could hat have happened. It wasn't like this before I tore it apart
78 KZ 400 C1-Daily Driver
New Albany,IN
New Albany,IN
Last edit: 30 Aug 2015 16:12 by Drafter89.
30 Aug 2015 16:09
It has a one piece crank as far as I know. The balancer settings are in your MANUAL.
30 Aug 2015 16:11swest wrote: It has a one piece crank as far as I know. .....
This is true. Ed
- Tyrell Corp
30 Aug 2015 16:15
Do these chain driven counterweights need timing according to crank position ? Remember you need to turn a 4 stroke motor over twice to get it back to the same position.
www.kzrider.com/forum/2-engine/8619-77-kz400-balancer
Damaged alternator rotor magnets can put an engine out of balance.
- missionkz
30 Aug 2015 16:16
I'd also be checking the compression to find out which valve is bent.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
30 Aug 2015 16:41 - 30 Aug 2015 16:43
The balancer is there for a reason. Last year I rebuilt a Aprilla 650 single. The balancer and water pump is gear driven. Then a cam chain is driven by a sprocket on a common shaft with the water pump gear. This makes the cam rotate BACKWARDS. :huh: Couldn't find any timing marks besides one on the left side I was working on. The cam sprocket had marks on it too. Two of THEM.
So I opened the right side. I found the timing mark on the alternator rotor and the timing trigger. The rotor had sheared all the #6m bolts. :ohmy: Normally I can figure most anything out but THIS, forget it. I paid the $35 for the manual on CD. Turns out the cam chain adjuster is oil pressure driven. When the bolts sheared, the bike lost power, the cam skipped a few teeth and the shop my neighbor Jeff took it to told him it was lunched. I got some #8 hardened bolts, reset the timing and it runs. He sold it for $3500, don't ask me how and I learned something. The engine was 1/2 made in Japan. It had French, Spanish and Italian parts. Shim over buckets and the most back assward engineering I've seen in a long time. So much for global engineering. :lol:
POINT is, if you don't have a manual, get one.
Last edit: 30 Aug 2015 16:43 by SWest.
The following user(s) said Thank You: Drafter89
- Drafter89
03 Sep 2015 04:54
Yep! Sure enough the balancer settings were all out of wack. put everything were it was supposed to be and will be firing her up this afternoon to see if everything worked. Thank god for shop manuals!! :laugh:
New Albany,IN
New Albany,IN
03 Sep 2015 05:35
There goes another happy customer.
- Drafter89
03 Sep 2015 06:20
Yes sir!
and it took me half the time to get the motor out and disassemble everything than it did the first time which im pretty happy about. Ima learnin
New Albany,IN
New Albany,IN
03 Sep 2015 06:47
"And the little Kaw shall lead." I like that. :woohoo:
