- Thank you received: 3
Removing cylinders
- Lazyman06
17 Aug 2015 19:55 #686161
by Lazyman06
1979 KZ1000 MK II frame
1980 KZ1000 C3 police engine
Removing cylinders was created by Lazyman06
Been trying to tear down the engine and I've got it down to the cylinders but I can't get it to budge an inch. Any suggestions?
- nickleo373
- Thank you received: 33
17 Aug 2015 20:01 #686162
by nickleo373
1981 KZ550C LTD
"If you ain't first, you're last"
Replied by nickleo373 on topic Removing cylinders
I don't know about your model, but on the 550 there is a small slot cut into the side of the engine where you can pry the cylinders up with a screwdriver or something
1981 KZ550C LTD
- Thank you received: 2749
17 Aug 2015 20:04 #686164
by SWest
Replied by SWest on topic Removing cylinders
Z1/KZ1000 too. I use a rubber mallet too.
- Lazyman06
17 Aug 2015 21:16 #686171
by Lazyman06
Replied by Lazyman06 on topic Re:Removing cylinders
Yep i saw the slots but didn't want to pry up too hard and break something
17 Aug 2015 21:28 #686173
by SWest
Replied by SWest on topic Re:Removing cylinders
Don't bop the fins but you can get it loose and pry it up enough to get them off.
- jeffo
17 Aug 2015 22:56 #686176
by jeffo
1981 KZ650H1 CSR
Replied by jeffo on topic Re:Removing cylinders
1981 KZ650H1 CSR
- Tyrell Corp
- Thank you received: 261
18 Aug 2015 03:55 #686183
by Tyrell Corp
Replied by Tyrell Corp on topic Re:Removing cylinders
I would spray plenty of release oil down the studs and around the gasket areas, light tap with a rubber mallet - be real careful here as the lower fins can break off so make your mallet hits contact several fins at once. There are cut outs in the base gasket for leverage points, use these only.
If the block is stuck you can cut two 1 inch plastic tubes or wood and put them in the bores, fasten cylinder head to block with the 5 m6 studs and turn the motor with a big lever to pull the block off. If that doesn't do it then removing or cutting through the 12 main studs is the next step.
18 Aug 2015 06:58 #686198
by SWest
Wait a minute. Pics, need pics.
- BohicaBob
- Thank you received: 35
18 Aug 2015 09:24 #686211
by BohicaBob
Replied by BohicaBob on topic Re:Removing cylinders
Best solution I came up with years ago to more easily remove the cylinder block on my Z1s and KZs is to make a steel bar that's thick (maybe 3/4" thick) and long enough to span the width of the cylinder block generously (so that you have room to use a mallet without hitting the block). It should be wide, like 3"-4" too. Drill 2 holes that line up with the two 6mm holes at the ends of the top sides of the block.
Use heavy duty bolts and bolt the bar onto the cylinder block securely. Use a heavy duty rubber or plastic mallet evenly and the block will come.
18 Aug 2015 11:13 #686226
by SWest
Some morons used Permatex. Nightmare.
- Lazyman06
18 Aug 2015 13:55 #686248
by Lazyman06
Top end is completely disassembled and I broke a screwdriver in the slot
18 Aug 2015 15:45 #686261
by SWest
Pics.
