Stock cam lift?
  • spdygon
  • spdygon's Avatar Topic Author
Stock cam lift?
17 Aug 2015 13:54 - 17 Aug 2015 13:56
#686109
Helping a friend out. Bike has 16k plus miles. We were checking the valve clearance and found all but one at .006 to .007.
We know they should be between.002 and .004.
He measured the cam lope and the it measure 362mm.
Is 362 the original cam lift?
My 79 kz1000 had z4 cams and it required.004 to .006 valve clearance.
So either he has after market cams or his cams are worn out.
Thoughts? His bike is a 78kz1000
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
Last edit: 17 Aug 2015 13:56 by spdygon.
  • OnkelB
  • OnkelB's Avatar
Re: Stock cam lift?
17 Aug 2015 15:05 - 17 Aug 2015 15:20
#686119
spdygon wrote: .
...He measured the cam lope and the it measure 362mm...
Umm, I think you mean 36.2 mm - 362 mm = 36.2 cm which is more than a foot long (1 foot = 304.8 mm/30.48 cm).
Is 362 the original cam lift?...
No, neither is 36.2. Measure the base circle, perpendicular to the lobe center line, then subtract that measure from the lobe heel-to-nose measure you already took (36.2 mm), the result is the lift.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 17 Aug 2015 15:20 by OnkelB.
Re: Stock cam lift?
17 Aug 2015 15:41
#686121
You state "We know they should be between.002 and .004."
Where did you come up with that specification? The KZ1000 Kawasaki Service Manual I have access to shows 0.05mm - 0.15mm which equals 0.002" - 0.006" Ed
  • racer54
  • racer54's Avatar
Re: Stock cam lift?
17 Aug 2015 16:03
#686123
Don't know exact lift figures but cam lift on these motors are around .300-.325 lift.
  • spdygon
Re: Stock cam lift?
17 Aug 2015 16:03 - 17 Aug 2015 16:05
#686124
I'll check again but my says
002 to 004 of an inch
.005 to .010 mm
Sorry...measurements are 006 and 007 of an inch
1974 Z1 900 project
Last edit: 17 Aug 2015 16:05 by spdygon.
Re: Stock cam lift?
17 Aug 2015 16:27
#686125
Here's the table from the manual I have. The manual covers the 1981 - 1983 models, but I wouldn't have thought the 1978 models would have specs that were much different. Ed
Attachment 00003a-89.jpg not found
Attachment 00003d-8.jpg not found
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Stock cam lift?
17 Aug 2015 16:40
#686126
I just checked a old Z1 900 cam and it measures 36.38mm from nose to base.
  • spdygon
Re: Stock cam lift?
17 Aug 2015 17:27
#686130
ok
he has stock cams....Intake is 36.22 Exhaust is 35.55
so safe to assume that his cams are worn out at the base?
Or what else would cause loose valve clearances?
Normally valves get tight.
1974 Z1 900 project
  • SWest
  • SWest's Avatar
  • 10 22 2014
  • missionkz
  • missionkz's Avatar
Re: Stock cam lift?
17 Aug 2015 18:25
#686141
I just measured my extra set of KZ1000a cams, with about 15,000 miles on them:
Intake> 36.36mm x 28.30mm = 8.06mm lift, or .317"
Exhaust> 35.85mm x 28.18mm = 7.65mm lift, or .301"
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Re: Stock cam lift?
17 Aug 2015 18:40
#686143
spdygon wrote: ok
No, the base should not be worn out. Nothing rubs on the base (that's why clearance is measured at the base), so it should not wear at all. Of course, if the owner has the valves so tight that there is zero clearance all bets are off, but that does not sound like it is the case here.
Valves do not always get tighter. I have had them vary a little both tighter and looser. Ed
  • Nessism
  • Nessism's Avatar
  • Online
Re: Stock cam lift?
17 Aug 2015 19:22
#686150
Valves almost always get tighter. Maybe someone that didn't know what they are doing changed the shims?
