Vacuum question
- gixxerkidd03
Vacuum question
27 Jul 2015 07:25
I got two questions for you guys. one is in regards to valve cover breathers. I have mine capped off. Would I have to worry about pressure building in the head or should it vent?
Second question should prob go under carbs, sorry. I have the carb vacuum capped off except #2 which runs to my petcock? Does this seem ok or should they be looped together? Thanks guys
81 kz750e
81 kz750e
1981 KZ750e
- loudhvx
Re: Vacuum question
27 Jul 2015 07:39
The breathers on the valve cover are not vents. They allow fresh air to flow into the exhaust. There will be no pressure build up. Leave them blocked (or connected to each other).
Don't combine vent tubes to the carbs if you don't have to. Just cap them. It shouldn't hurt to combine them, but if there is no reason to, it's better not to. If one manifold develops a vac leak. it will be harder to figure out which one, if the vacuum tubes are combined.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
Re: Vacuum question
27 Jul 2015 08:04
I did that years ago. It was said it would even out the carbs. BUNK I had pretty blue hoses connecting them. Looked cool but that's all.
- missionkz
Re: Vacuum question
27 Jul 2015 09:21Me too. I noticed no change. Probably because the carbs were set up correctly and sync' right anyhow.swest wrote: I did that years ago. It was said it would even out the carbs. BUNK I had pretty blue hoses connecting them. Looked cool but that's all.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- gixxerkidd03
Re: Vacuum question
27 Jul 2015 09:47
Right on, thanks guys. I've been running it this that for some time with no issues. I just had a friend question it the other day.
Here's another question for you:
I had the pleasure of Doing a starter clutch in my bike this weekend. What's the trick to holding the clutch basket and torquing the center bolt to 96 ft lbs?
1981 KZ750e
Re: Vacuum question
27 Jul 2015 11:24
If you don't have the tool, try using the rear brake.
- loudhvx
Re: Vacuum question
27 Jul 2015 13:16Ahh. So relaxing, like a perfect glass of lemonade on a sunny afternoon. :laugh:gixxerkidd03 wrote: ... I had the pleasure of Doing a starter clutch in my bike this weekend....
1981 KZ550 D1 gpz.
Other links.
Other links.
- Tyrell Corp
Re: Vacuum question
27 Jul 2015 15:20
I link the carbs 1/4 2/3 .plus a T on one to the fuel tap, either it makes no difference or slightly helps carb balance, certainly won't do any harm.
You can lock the engine for the clutch centre nut with the brake or a timber through the back wheel. An air tool is invaluable here, I've done this by hand before but it needs to be mega tight . FSM advises replacement of the nut whenever disturbed.
Attachment 143803467752629.jpg not found
- gixxerkidd03
Re: Vacuum question
28 Jul 2015 22:01
That looks like the ticket. On a side note, I rebuild my starter today and tried to fire the bike but it seems like I may have fried my starter relay from cranking it to much when my starter clutch went. I tried to jump the two large terminals on the relay thinking I could jump the starter but I got nothing ? I ordered a new relay but I'm hoping to find one local tomorrow. But it doesn't seem like something any shop or dealer ship would have in stock. I'm tiring to get my bike running for a show/ ride here I'm portland on Sunday. Is it possible even after I rebuilt the starter ( brushes, bearings, thrust washers,ect) that the Starter could still be bad? Thanks guys
1981 KZ750e
