- Thank you received: 3
KZ650 rough idle, hunting, pop and dies when hot
- cjaldous
I've tried spraying carb cleaner near the carb holders, and can't get a response.
I'm having a hard time determining if this is carb, electrical or engine related.
The fuel level might be low by a mm, 2mm at most and the jets are clean.
The coils are new and the battery is charged. The valve clearances are good.
One other thing I noticed is that the bike didn't seem respond much to the air screws.
What do I check, or re-check next?
1977 KZ650B
- Irish Yobbo
- Thank you received: 93
After running it for a while without the choke, stop the engine and check the spark plug. It should be clean-ish and brown. If it's white, you're running lean. If it's black and sooty, running rich. While you're at it you can check the spark plug gap, as that could be it too.
1981 KZ750 LTD
- Thank you received: 2749
- cjaldous
I'll check the gaps, but I recall they were correct.
I've got a chopped exhaust (that might not be from a KZ650), it's missing the cross piece between the sides.
Cheapo pod filters, 15 pilots, 107.5 mains with needle cir clip third(middle) position.
My float needles have very slight wear, 3 are 2.0 and 1 is 2.5.
Fuel level is maybe a mm or so low last time I checked.
I haven't adjusted the valves. They varied from 0.10 to 0.15mm (4 to 6 mil)
1977 KZ650B
- Irish Yobbo
1981 KZ750 LTD
- Thank you received: 2829
You state that the plugs are black. Assuming it's soot rather than oil, I strongly suspect the problem is jetting. If someone cut the exhaust system up and put pods on the bike it is highly likely they did not find the magic formula for jet sizes when fiddling with the carbs, and as a result the air/fuel mixture is too rich. Ed
- Tyrell Corp
- Thank you received: 261
- Thank you received: 2098
cjaldous wrote: . . . Cheapo pod filters . . . .
Reportedly, some pod filters may block the carb's pilot air entrance.
Could test run without the pods to determine whether there's any change in lower rpm performance.
If not already done, would assure that the advancer unit is properly functioning by viewing its operation under a timing light while watching it move quickly back and forth as rpm is varied by blipping the throttle.
Entrance to the #2 pilot air passage is the area subject to being sometimes obstructed by a pod filter.
- KZB2 650
- Thank you received: 265
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
