Spark Knock
- Tyrell Corp
Re: Spark Knock
30 Jul 2015 10:47
I'm wondering if it is fuelling, sometimes ignition and carb problems can be difficult to tell apart.
From the description it sounds like it could be a main jet badly wrong. It feels like your ignition is misfiring all over the place when in fact it is a main jet problem.
Re: Spark Knock
30 Jul 2015 11:03
Broken piston skirt?
- The_Proletariat
- "Cocaine is a hell of a drug"
Re: Spark Knock
01 Aug 2015 20:39Tyrell Corp wrote: I'm wondering if it is fuelling, sometimes ignition and carb problems can be difficult to tell apart.
It was too rich. The spark plugs were black.
The needle jet clip works well at the 3rd position with ethanol laced gasoline but it needs to be on the second position with straight gas.
1982 Kawasaki KZ550 LTD
- loudhvx
Re: Spark Knock
02 Aug 2015 10:52
So it probably was not a knock issue then, but a misfire issue. That can sound like a knock.
I've recently found there is a company making rebuild kits with essentially defective needles. They are too skinny by a couple thousandths. This makes it so they are too rich, even at the maximum lean clip setting. They are using the Keyster part number to masquerade as a Keyster kit. I'm still writing it up. It'll be on the TK22 site, hopefully in the near future.
1981 KZ550 D1 gpz.
Kz550 valve train warning.
Other links.
Other links.
The following user(s) said Thank You: Tyrell Corp
- The_Proletariat
Re: Spark Knock
02 Aug 2015 14:28 - 02 Aug 2015 16:09
I guess I am going to take that back.
I switched to the second clip on the needle jet. I filled up with regular ethanol laced gas. The bike ran fantastic for about 10 miles.
Today, it started the same garbage. Bogging down over about 1\3 throttle in gears 3 and up. I tore the carbs down and two emulsifier tubes were nearly clogged. How can this happen? I have always used a fuel filter. I hope this is my problem. If not, I don't know what to do.
I also broke the timing chain tensioner removing the carb bowls. I now have to call off work until I can locate another one. I am in trouble here.
Last edit: 02 Aug 2015 16:09 by The_Proletariat.
Re: Spark Knock
02 Aug 2015 16:32
What kind of air filter do you have?
- The_Proletariat
Re: Spark Knock
02 Aug 2015 17:16 - 02 Aug 2015 17:23swest wrote: What kind of air filter do you have?
Emgo, inside the airbox. Around 2000 miles on it.
In addition, there was tons of garbage in the fuel tank. The petcock strainer was full of debris about halfway up.
I have cleaned this up as best as I can but I am now at a standstill until I source another tensioner.
Last edit: 02 Aug 2015 17:23 by The_Proletariat.
- missionkz
Re: Spark Knock
02 Aug 2015 17:31
Are you using a fuel filter set up after the tank selector ..... Before the carbs?
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- missionkz
Re: Spark Knock
02 Aug 2015 17:32 - 02 Aug 2015 17:33
i wrapped my pickup tubes in the tank with filter material and safety wire. Works great as a primary filter.
Bruce
1977 KZ1000A1
1977 KZ1000A1
Last edit: 02 Aug 2015 17:33 by missionkz.
- The_Proletariat
Re: Spark Knock
02 Aug 2015 18:40 - 02 Aug 2015 18:46missionkz wrote: Are you using a fuel filter set up after the tank selector ..... Before the carbs?
Yes, a sintered bronze filter meant for lawnmowers and such. I know the pleated paper style ones filter better but they won't flow without a pump in my experience.
I was shocked to see so much crap in the carb bowls. Strangly enough only carbs 3 and 4 were affected. 1 and 2 were very clean.
Where did you source this filter material?
Last edit: 02 Aug 2015 18:46 by The_Proletariat.
Re: Spark Knock
02 Aug 2015 18:53 - 02 Aug 2015 18:54
Here's what I use. Not cheap, but a great filter that is very small, filter element can be cleaned, passes up to 6 gallons per minute, and filters 10 micron particle size. I've had it on for 4,000 miles; no problems. Ed
www.kzrider.com/forum/3-carburetor/59406...ne-and-filter#633243
Last edit: 02 Aug 2015 18:54 by 650ed.
- The_Proletariat
Re: Spark Knock
02 Aug 2015 20:32 - 02 Aug 2015 20:38650ed wrote: Here's what I use. Not cheap, but a great filter that is very small, filter element can be cleaned, passes up to 6 gallons per minute, and filters 10 micron particle size. I've had it on for 4,000 miles; no problems. Ed
A little beyond my budget, but that looks like a quality piece.
Last edit: 02 Aug 2015 20:38 by The_Proletariat.
