Cam clearance on different on GPZ head than KZ1000
- tomsbadkz
11 Jul 2015 15:44
I have read about clearancing lifter bores and cam covers. Is the any difference on the highest lift allowed before clearancing is required on the 83-84 GPZ1100 head compared to 73-80 KZ1000 head? Make sense?
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
Re: Cam clearance on different on GPZ head than KZ1000
11 Jul 2015 21:28
Are you asking about installing bigger cams?
- DFIGPZ
11 Jul 2015 21:33
all depends on what cams you are using.
1984 750 Turbo
- tomsbadkz
12 Jul 2015 03:43
DFIGPZ, I sent you a pm earlier.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
- tomsbadkz
12 Jul 2015 03:46
Web Cams 465/435 w/ 1.00 b.c.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
12 Jul 2015 06:03
Pretty aggressive cams. Overbore? Different pistons?
- Old Man Rock
12 Jul 2015 06:41 - 12 Jul 2015 06:48
Pretty much the answer is yes....
NOTE: As mentioned pending which cam you're speaking of...
Keep in mind, go too big and you need to go under bucket shims so mods required.
Another example, '78KZ1000 head in my build using GPZ1100 cams... Lobes longer so have to mod. (Top 5 images)
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 12 Jul 2015 06:48 by Old Man Rock.
12 Jul 2015 07:16
I am pretty sure that the op is asking if the GPz1100 head and cam cover need to be clearanced for the cams he will use, in the same way that a KZ head would.
12 Jul 2015 07:21
They would, wouldn't they?
12 Jul 2015 07:22
I take that back. Put them in and see for yourself.
- tomsbadkz
12 Jul 2015 09:13
bored? yes. 1327 big block 10.5 to 1. head done by LarryC. 84 zn1100 head with 38.6 intakes and 33 exhaust. tianium reatainers with MTC shim under buckets, flowing 107cfm. KZ bottom end with Falicon 16 tooth crank.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
12 Jul 2015 11:58
On the J head, anything over about .395 lift on a standard base circle (1.10) will need additional clearance in the follower bores and on the cam cover ribbing. I suspect that the GPz has the same clearance problems, though his cams have a smaller base circle, so I dunno.
