KZ440 Timing advancer...Rebuild?
  • DrMotorBoat
  • DrMotorBoat's Avatar Topic Author
01 Jun 2015 13:27 - 01 Jun 2015 14:02
#674796
Hi guys,
I have a 1981 KZ440LTD. I was having some performance issues (wouldn't get up to speed at all) and started looking at the manual and at the forums. Realized my timing advancer was stuck. I did a stupid thing and put some oil on it and tried to work it loose. The trying to work it loose did not go well and I broke off the little tab on one of the arms. It is the little nub that makes the cam move. I cannot find any replacement parts.
This is an electronic ignition (no points).
So here are my questions:
1) how do you get the bolt loose in order to get the timing advancer out... My bolt is seized. So far a little WD-40 is what I have put on it...
2) is it possible to rebuild the timing advancer? As far as I can tell, all I need is one of those "arms". Has anyone pulled one of these apart and put it back together? If it is possible to rebuild it using the arm from another timing advancer, does anyone know any specific advancer model I should be looking for?
I have the shop manual and clymers manuals... but please explain like I am 5 years old. :)
Thanks so much,
1981 KZ 440 LTD
Last edit: 01 Jun 2015 14:02 by DrMotorBoat.
  • missionkz
  • missionkz's Avatar
Re: KZ440 Timing advancer...Rebuild?
01 Jun 2015 14:54 - 01 Jun 2015 14:55
#674812
This could be the Kaw number, 21148-1021
The bolt (not the locking nut under it) should just come loose but if the bolt breaks, you can slide the nut and advance plate off and the figure out how to get the bolt out of the crank end by various methods later.
As far as the advancing weight goes, I'd go to a moto junk yard and get one, the whole thing couldn't cost more the $25 at a moto bone yard... there were thousands of these made.
If not found, and there is no other solution, I think any small weld shop worth a darn could burp a little tab on there where you could file it to fit the groove in the advance cam bushing.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
Last edit: 01 Jun 2015 14:55 by missionkz.
  • martin_csr
  • martin_csr's Avatar
01 Jun 2015 15:50 - 01 Jun 2015 15:51
#674829
Use a penetrating oil. Kroil is supposed to be best. Liquid Wrench penetrating spray lubricant is good, readily available & cheap. (wd40 isn't really a penetrant). I would try to get a replacement advancer on eebbaayy. You can probably use one from any 440 w/ electronic ignition (1981-&-on. maybe an 80 model, but those are supposed to have points ignition, so maybe not).
Last edit: 01 Jun 2015 15:51 by martin_csr.
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jun 2015 16:05
#674835
I think mission nailed it. The bolt is a 13mm. The nut is meant to be used to turn the crank. It's 17mm. If you cant get the 13mm to budge, tap it with a hammer. I don't mean HAMMER ON IT. :woohoo: It should come off easally. :whistle:
Remember;" righty/tighty, lefty/ loosey." :laugh:
The following user(s) said Thank You: Greybeard
  • Nebr_Rex
  • Nebr_Rex's Avatar
01 Jun 2015 18:43
#674870
The crank turns backwards on the KZ400/440 com paired to the 4 cyl. engines.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jun 2015 18:45
#674871
That explains it. Left hand threads. :huh:
  • missionkz
01 Jun 2015 19:14
#674884
YIKES!! I did not know it had left hand threads on the crank end! The could really mess up a lot of DIY'r, home shop mechanics.
Bruce
1977 KZ1000A1
  • SWest
  • SWest's Avatar
  • 10 22 2014
01 Jun 2015 19:24
#674889
Yeah, that could make for a FK'ed up day alright. :ohmy:
  • bountyhunter
  • bountyhunter's Avatar
01 Jun 2015 22:00
#674921
bakerco3 wrote: Hi guys,
Thanks so much,
Kroil is way better than WD-40 for freeing stuck parts. Yes, you can rebuild an advancer. I did on my 750 twin, I had to make new springs which was a royal pain in the ass.
I have seen advancers on ebay.
  • dom2570
  • dom2570's Avatar
Re: Re:KZ440 Timing advancer...Rebuild?
02 Jun 2015 06:26
#674957
swest wrote: That explains it. Left hand threads. :huh:
The timing advancer on the 440s, at least the two I own, are not left hand threaded.
Whip it like a mule!
  • martin_csr
02 Jun 2015 07:44
#674964
dom2570 wrote: The timing advancer on the 440s, at least the two I own, are not left hand threaded.
That seems to be correct, as the 440s have the same timing advancer bolt as my 81 650-CSR & it is RH-threaded.
If the crankshaft spins counterclockwise, then I guess a locking agent is kinda important.
  • dom2570
  • dom2570's Avatar
02 Jun 2015 08:55
#674974
The only left had threaded bolt on the kz440 that I am aware of is the center bolt on the crank that holds the generator on.
