KZ440 Timing advancer...Rebuild?
- missionkz
Re: KZ440 Timing advancer...Rebuild?
02 Jun 2015 12:38
Take a picture of what you have there and post it!!
Many of us have lots of old parts from various, previously owned bikes just tossed in our
junk boxes.
junk boxes.
Bruce
1977 KZ1000A1
2016 Triumph T120 Bonneville
1977 KZ1000A1
- DrMotorBoat
03 Nov 2015 08:43
Hi Everyone,
Thanks for all of the feedback here. This place is awesome. I have been busy with new baby and work and haven't had a chance to look at it (I know, I know). Do we have any consensus on whether I should be working the bolt clockwise or counter clockwise to get it off? I will send pics once I can do that.
Thanks everyone!!!
Thanks everyone!!!
1981 KZ 440 LTD
- dom2570
Re: Re:KZ440 Timing advancer...Rebuild?
03 Nov 2015 09:43 - 03 Nov 2015 09:45
You can spray a bit of penetrating oil on it. Use a 17mm wrench to hold the crank in place, the use a 13mm socket to remove the bolt. It is a standard thread, lefty loosely rightie tightly.
If you try and remove the 13mm without using the 17mm to stop the crank from turning over, you can snap the stud that holds the advancer in place.
Whip it like a mule!
Last edit: 03 Nov 2015 09:45 by dom2570.
The following user(s) said Thank You: Greybeard
03 Nov 2015 10:19
Post a pic. I just cannibalized a advancer off a 750 and still have the weights and everything except the springs. If it will work for you, you can have it.
