Cam positioning for Andrews cams on a 76 kz650
- zed1015
Re: Cam positioning for Andrews cams on a 76 kz650
14 May 2015 13:33You can't alter the duration of the cams as this is fixed in the grind.Dirtyhands wrote: Are big cams like this ok to run at a longer duration? I've considered just putting some 750 cams in instead, let me know what you think.
Zac
You can only alter the lobe centres to shift the power characteristics up or down the rev range.
If you don't have the manufacturers recommended figures for timing them you should start by dialling them in on the lobe centre figures given for the STD cams for your bike .
This may not get the best out of these cams but will give you the best shot at usable power and a starting point for further adjustment.
Looking at other performance cam figures for your bike with the same or similar lift/duration will give the best indication of where these may work the best.
The following user(s) said Thank You: Dirtyhands
14 May 2015 14:01
If you can get a set of 750 cams and sprockets for cheap, I'd get them. At least you will be able to compare them and be riding if not sure.
- Dirtyhands
16 May 2015 00:22
Today I hooked up the degree wheel and dial indicator and dialed in the cams. I first checked the Lift at .040 and found that the intake was set at 16 BTC / 57 ADC which gave me a lobe center of 110.5 The Exhaust was at 56 bbc 18 adc which gave me a lobe center of 109. I decided to try to dial them into The Megacycle .410 cam specs since those have the same lift as what I'm working with. I managed to get the intake set square onto 20btc 50abc with a lobe center of 105 and the exhaust at 52bbc 23atc with a lobe center of 104.5. I've attached the megacycle specs below. What do you guys think? this is my first time degreeing so I want to make sure I'm on the right track before sealing er up.
Attachment Mega_Cycle_Cams.jpg not found
1977 KZ650B
KZ750H Motor Installed
gpz750 Intake cams Kz750 Exhaust Cams
VM28SS Mikuni Pumper Carbs
Elecrosport Stator and Regulator Rectifier
Dyna 3ohm coils
Derale Oil Cooler
4into1 delkevic Pipes
Pod Airfilters
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
- Nebr_Rex
16 May 2015 02:43
The duration is very close. You may have found the answer to your question.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- Old Man Rock
16 May 2015 06:22 - 16 May 2015 06:22
See if this will allow me to attach the Zombie doc.... (MODS... need to be able to upload pdf files)
Attachment MOTORCYCLECAMDEGREEINGFORZOMBIES.doc not found
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
MTC 1075cc.
ZX636 suspension
MIKUNI, RS-34'S...
Dyna-S E.I.
Phoenix, Az
Last edit: 16 May 2015 06:22 by Old Man Rock.
- kawi810
16 May 2015 08:42 - 16 May 2015 08:47
i am running Megacycle cams in my 810 cc part #47110 here is the timing card .
original owner of a 1984 gpz 750
1985 turbo 750 stock, being restored.
1984 gpz 750 with 810 cc wiesco's megacycle cams(471-10) 34 mm flatslides v&h pipe ported head dyna ignition. bottom end, crank case from turbo 750 and sprockets.
Last edit: 16 May 2015 08:47 by kawi810. Reason: keep getting fatel 500
- kawi810
16 May 2015 08:53 - 16 May 2015 08:54
can not upload pics i keep getting 500 fatal server error
Last edit: 16 May 2015 08:54 by kawi810.
- Dirtyhands
16 May 2015 12:09
Thank you for posting the Zombie tutorial Old Man Rock! I'll give it a good read and recheck my work. I was going back and forth between the
cavanaughracing.com
tutorial and Web cam shafts tutorial but definitely still had some questions the zombie will probably answer.
Hey kawi810 is there more info on the cam card than listed on the megacycle spec sheet I posted? How are you liking them in your bike?
1977 KZ650B
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
Dyna 3ohm coils
Derale Oil Cooler
Pod Airfilters
- kawi810
16 May 2015 12:17 - 16 May 2015 12:34
yes exhaust specs are 53 bbc 17 atc and my lobes have smaller radius
Last edit: 16 May 2015 12:34 by kawi810.
- kawi810
16 May 2015 12:19
i still can not post any pics do not know why and these cams come alive at about 5-6000 rpms and pull untill 11000
- kawi810
16 May 2015 12:25 - 16 May 2015 12:26
kzrider.com/forum/11-projects/596648-810-cc-rebuild#655506
these are the cams in the pics.
Last edit: 16 May 2015 12:26 by kawi810.
