Somebody PLEASE HELP!!!! :angry:
  • Gjason89
  • Gjason89's Avatar Topic Author
14 Apr 2015 17:36
#667950
:angry: 1982 ltd 550!!
Im fed up with doing all this research asking all these questions doing all these things cleaning carbs checking for spark even made a new simple wire harness that came out pretty good purchased used but fairly new ic igniter even got a Cdi off eBay since I didn't have one new spark plugs new cables!!! Checked timing with piston at top dead center even new pulsed coils!!!! And still I get not even a studder of it coming back to life!!!! Just a simple back fire with black smoke from mufflers and a puff or some sort threw the carbs!!! Compression seems good !! Ps when I turn the engine threw the ignition magnet it turns pretty stiff then at some point it gets fairly easier than rest . I'm to the point were considering I have no money and no job since I my last bike was stolen and crashed!!! I'm beginning to think that I'll have to find a way and pay a motorcycle shop!!! This bike needs to be running soon I've already gotten new gas tank got it painted and ready got tires on the way too!!!
  • SWest
  • SWest's Avatar
  • 10 22 2014
Re: Somebody PLEASE HELP!!!! :angry:
14 Apr 2015 17:45
#667952
Did you lay your plugs on the head touching a bolt to see if you have spark?
The following user(s) said Thank You: Gjason89
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
14 Apr 2015 18:52
#667963
Where do you live? Do you have a Kawasaki factory manual ?
Take 2 shots of Gentleman Jack and call me in the morning .
Im not a 550 guy , but someone here should be able to talk you thru your problem. These bike are pretty easy if you don't get mad
  • Nebr_Rex
  • Nebr_Rex's Avatar
14 Apr 2015 19:32
#667968
Compression, fuel, spark, which one don't you have?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: missionkz
  • Gjason89
14 Apr 2015 19:55
#667974
I have put it on bolts and definitely have spark. It's getting fuel everything checks out compression I haven't tested with a gauge but they all suck or push out I don't really have a clue anymore.
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Apr 2015 20:16
#667977
If you don't have a gauge you can put your finger over the hole and turn it over with the starter. If you can hold it there, no runable compression. A lot of times the PO didn't know how or want to go through the hassle of adjusting the valves. They'll just ride until it won't run anymore, then sell it. That could be it. Check them.
  • RonKZ650
  • RonKZ650's Avatar
14 Apr 2015 20:28
#667981
Also if it's not your motorcycle previously could be the cams were installed incorrectly by previous innept maintenance. KZ550 timing not difficult, but possible to do wrong.
  • Gjason89
14 Apr 2015 20:28 - 14 Apr 2015 20:36
#667982
When I remove them I get suction or a push up I guess suction when piston is going down and when coming back up it pushes it put the bike only has 9000 miles I would say it's fairly in good condition another thing just this weekend I realized that the timing was actually really of I saw a picture of how they both are suppose to align with the edge of engine were gasket goes and fixed the cams to we're they are there with piston at TDC I even thought I did it wrong so I even went over it all again and recounted the pins on the chain to the marking on cam sprocket were chain goes on and everything seems pretty good actually . Must I mention when I got it the exhaust and engine was pretty dirty with like oil but a really grease like for example around the sprocket of the chain to rear tire I thought something has to be wrong there no engine just magically gets that dirty
Last edit: 14 Apr 2015 20:36 by Gjason89.
The following user(s) said Thank You: Randombeat
  • SWest
  • SWest's Avatar
  • 10 22 2014
14 Apr 2015 20:53
#667987
Did you measure the valve clearances? You shouldn't be able to hold your finger over the hole while it "pushes".
  • Gjason89
14 Apr 2015 21:24
#667989
No that's one thing I haven't done checked the valve clearances simply because I don't know what the purpose is and how I've only helped doing that once on a moped but didn't quite understand it.
  • riturbo
  • riturbo's Avatar
14 Apr 2015 22:13
#667993
You have the plug wires on the right plugs
Gpz 750 turbo The one I ride
Gpz 750 turbo Not finished
Gpz 750 turbo Not started
Gpz 550 1981
Gpz 550 1983
Bunch of other junk
  • Gjason89
14 Apr 2015 22:34
#667994
Yes isn't it 1 and 4 together and 2 and 3 I think I've gotten past all that al pretty much learned most of that stuff hoping it be many of things id say my last thing would be what Steve said the valve clearances that would be maybe my last thing if could be I really really hope it fires
