Torque specs for oil pan
  • Racewayelko
  • Racewayelko's Avatar Topic Author
10 Feb 2015 19:08
#661191
So I was reading through my clymer manuel while doing my pan gasket on a 4 cyl 1982 kz750 and saw that I am supposed to torque the pan bolts to 90 ft lbs. Does this seem high to anybody else? I don't want to strip out the threads. Also I am using rtv copper so would that effect how much I torque it. Also small rant on cv34's The small o ring on the plastic plugs are $10 from the dealer.. Why so much for something smaller than my pinky finger.
Keep it rubber side down everyone :)
Klx 110, TTr125, TTr250, 1982 kz750-N1 (Spectre), Xt-350 (soon to be the new home of a Kz550 engine :) )
  • DFIGPZ
  • DFIGPZ's Avatar
Re: Torque specs for oil pan
10 Feb 2015 19:23
#661197
90 INCH POUNDS.
1984 750 Turbo
10 Feb 2015 19:24 - 10 Feb 2015 19:24
#661198
Racewayelko wrote: So I was reading through my clymer manuel while doing my pan gasket on a 4 cyl 1982 kz750 and saw that I am supposed to torque the pan bolts to 90 ft lbs. Does this seem high to anybody else? I don't want to strip out the threads. Also I am using rtv copper so would that effect how much I torque it. Also small rant on cv34's The small o ring on the plastic plugs are $10 from the dealer.. Why so much for something smaller than my pinky finger.
Probably 87 in-lbs --- That's INCH-pounds. Not foot-pounds.
Here's a link to another service manual.
mbsween.bike-night.com/kz750l3/index.html
Scroll down to the Bible, and download the manual.
Check out page 35 and also page 77.
Good Fortune! :)
Last edit: 10 Feb 2015 19:24 by Patton.
  • Racewayelko
10 Feb 2015 21:19
#661223
ohhhhh that would make more sense.. man I gotta find my glasses, and read more carefully.. Thanks!!
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Feb 2015 21:23
#661225
As for the O rings, why does a dog lick himself?
The O rings are metric, hard to find.
  • Racewayelko
10 Feb 2015 22:13
#661230
I wish I knew what the size was. Z1 has Keihin gaskets for super cheap (under a dollar per one) but I don't know the size Oh well, will have to cough up the cash for them I guess
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Feb 2015 07:07
#661264
Time is money. You could try the auto parts stores. They have a box of different sizes. Sometimes they're too fat. Heavy equipment hose repair places carry O rings too.
  • Tyrell Corp
  • Tyrell Corp's Avatar
11 Feb 2015 14:28
#661319
Unless you have a small tourque wrench that is calibrated I'd just do it by feel. A lot of big 3/8 long wrenches are for cars and on low settings can be a lot out.
The following user(s) said Thank You: PLUMMEN
  • TexasKZ
  • TexasKZ's Avatar
11 Feb 2015 17:42
#661336
Tyrell Corp wrote: Unless you have a small tourque wrench that is calibrated I'd just do it by feel. A lot of big 3/8 long wrenches are for cars and on low settings can be a lot out.
+1
  • Racewayelko
11 Feb 2015 18:30
#661345
the next question is do I trust my 1/4 torque wrench (in-lbs) from harbor freight with these bolts? I think I will just go somewhat snug with a normal ratchet
  • SWest
  • SWest's Avatar
  • 10 22 2014
11 Feb 2015 19:35
#661356
If you have a 1/4 wrench, use it. Can break a bolt,strip or pull threads out with a 3/8's.
  • PLUMMEN
  • PLUMMEN's Avatar
11 Feb 2015 22:03
#661364
Start in the center and work your way out on each side with a 3/8 drive ratchet,just snug em up really good.
Check them after a couple hundred miles,it aint rocket science boys. :laugh:
