Torque specs for oil pan
  • F1schumie
  • F1schumie's Avatar
Re: Torque specs for oil pan
11 Feb 2015 23:36
#661368
Best bet for any torque settings is go by bolt size..
Also if torquing use blue lock tight
If no tq wrench and using smaller fasteners use just a box or open end wrench and use you pinky finger as your tention gauge ..
Too often people use ratchets and over torque strip and snap bolts.. especially into aluminum with old bolts..
every gasket and mating surface is different ... use "foreplay" when building your bike...
She will treat you right if you build and take your time and build with feeling..
J
12 Feb 2015 04:24 - 12 Feb 2015 04:25
#661377
There is no need at all to use blue lock tight or any other locking agent on the fasteners except where specifically called for in the manual. In fact, if you read the torque specs carefully you will find that they are intended to be used with fasteners that have dry, clean threads. Having followed the torque specs in the Kawasaki Service Manual for 38 years I have never had a fastener come loose, strip threads, or had any fastener related leaks. Ed
Last edit: 12 Feb 2015 04:25 by 650ed.
The following user(s) said Thank You: pete greek1, Racewayelko
  • Tyrell Corp
  • Tyrell Corp's Avatar
12 Feb 2015 15:19
#661419
Trust your hands man - 'feel' it.
About 25 years ago as a keen teenager I was religiously following manual settings for tourques, and broke far too many bolts and stripped threads with my 3/8 wrench.
Cylinder heads, big end bolts, clutch centre nuts etc etc are very important to use correct tourque wrench...most other fasteners it is not critical other than they are 'tight'.
Sometimes the bolts can stretch and snap after a few uses -I always replace cam cap bolts with new high tensile steel.
  • Racewayelko
  • Racewayelko's Avatar Topic Author
12 Feb 2015 20:51
#661445
went by feel, then checked with torque wrench, was close on all bolts, just checked them with a beam style torque wrench in in/lbs. THank you everyone!!
Keep it rubber side down everyone :)
Klx 110, TTr125, TTr250, 1982 kz750-N1 (Spectre), Xt-350 (soon to be the new home of a Kz550 engine :) )
