OIL LEAK
- spdygon
OIL LEAK
08 Feb 2015 11:15
Well i had replace Tech seal and Vavle cover gaskets...but looks like oil leak coming from bewteen the block and head.
Will have to wait till next Winter for repairs.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
Re: OIL LEAK
08 Feb 2015 11:48
Is that a one piece head gasket?
- pete greek1
Re: OIL LEAK
08 Feb 2015 12:12
Did you try to Re torque the Head bolts, in the proper sequence ??
Pete
Pete
- spdygon
Re: OIL LEAK
08 Feb 2015 12:48
Just bout the bike two month ago.....If i open it up now ill want to do more then just the gasket needed.
So ill just have to wait....more of a reason to wash it more often :laugh:
1974 Z1 900 project
1974 Z1 900 project
Re: OIL LEAK
08 Feb 2015 17:43
Unless it it is gushing like mine was, I'd leave it be. I hated having oil stains on my left boot. Always seems to travel that way.
- daveo
Re: OIL LEAK
08 Feb 2015 17:51
It appears to be running down from above that point, when looking closely at your photo.
If mine, I'd clean off all the oil evidence from the head and cylinder block, and check it again after a few rides. Don't tear it apart until absolutely sure where it is coming from.
1982 KZ1100-A2/1170 sleeper 😀
Re: OIL LEAK
08 Feb 2015 18:00
I saw that too. Are you sure you don't have a crack in a bolt casting? There's no oil in the head bolt in that area.
- spdygon
Re: OIL LEAK
08 Feb 2015 18:15
my be a crack ...it looks like coming from between the block.
they are two expose head bolts..one on each side of the chain guide.
will wash again and look at it again after a ride.
1974 Z1 900 project
1974 Z1 900 project
- Xl ED
Re: OIL LEAK
08 Feb 2015 19:12
If you wash it up good and then spray ladies antiperspirant all over and then run it you should be able to tell where the leak begins.
I don't live to ride, I ride to live.
Re: OIL LEAK
08 Feb 2015 19:16
She'll be mad as hell but it should work.
- pete greek1
Re: OIL LEAK
09 Feb 2015 10:54
If the suspected area is clean & dry, you can pour some Baby Powder in the area, start it up & wait to see where it's leaking
Pete
Pete
- Xl ED
Re: OIL LEAK
09 Feb 2015 13:40
Then don't tell her Steve! Baby powder will work too.
