cylinder studs
- 123vucku
cylinder studs
07 Jan 2015 20:12
Taking apart my motor to replace my head gasket on a 1976kz900 a4 I noticed as I took of my two half gaskets they were soaked in oil towards the exhaust side of the motor where it was leaking... Also my cylinder studs on on the exhaust side 1 and 4 have like a puddle of oil in there little spots I feel that isn't right not sure . Wondering if I should get the ape studs . Someone please tell me if it's normal or if my studs need replacing . Thank you
- zukdave
Re: cylinder studs
07 Jan 2015 20:29
Pull your bike up on Partszilla and look at the
part's break down I think some studs have an O-ring.
1980 KZ650 F1
ZX750A1 motor.
Wiseco 810cc kit.
Zukiworks racing ported head.
VM 29 smooth bore's.
APE valve spring's.
APE Track King clutch.
V/H KZ1000 sidewinder.
150/60/18 Shinko 006 Podium.
63" wheel base.
ZX750A1 motor.
Wiseco 810cc kit.
APE valve spring's.
63" wheel base.
The following user(s) said Thank You: PLUMMEN
- daveo
Re: cylinder studs
08 Jan 2015 03:55zukdave wrote: Pull your bike up on Partszilla and look at the
1982 KZ1100-A2/1170 sleeper 😀
- z1kzonly
Re: cylinder studs
08 Jan 2015 06:07 - 08 Jan 2015 06:10
Relax. The 4 corner studs are the oil galleys that deliver the engine oil to the top end. And this leak is common and normal on older engines that have been together for a long time.
The trick is to make a very thin 3/4 moon bead of RTV on the block, (that's the top of the cylinder block) at the 4 corner studs about an 1/8" back.
Let the RTV set up and cure a day before you put the head on and assemble.
Last edit: 08 Jan 2015 06:10 by z1kzonly. Reason: more words
- 123vucku
Re: cylinder studs
08 Jan 2015 08:02
OK yea u thought so but wasn't sure and do u mean like the hole the stud goes through ? Make a bead around there right just so it doesn't seep? And thank you and 1/8 back do u mean down the hole 1/8
- 123vucku
- z1kzonly
Re: cylinder studs
08 Jan 2015 08:46NO! Not near the hole!!! That,s were the oil flows up to and into the head.123vucku wrote: OK yea u thought so but wasn't sure and do u mean like the hole the stud goes through ? Make a bead around there right just so it doesn't seep? And thank you and 1/8 back do u mean down the hole 1/8
You want it back at least a 1/4" away from the studs. I don't have a bare cylinder the show you with a picture.
The oil flows from the lower end up through 4 outer cylinder studs. Look at your cylinder head, at the 4 outer stud holes and you can see the oil passages, which let the oil flow into the head.
I always just did it by feel and repetitiveness over 40 years.
- 123vucku
Re: cylinder studs
08 Jan 2015 20:50
If I put a bead there shouldn't I put a bead all around ?
- KzChop82
Re: Re:cylinder studs
10 Jan 2015 05:43z1kzonly wrote: Relax. The 4 corner studs are the oil galleys that deliver the engine oil to the top end. And this leak is common and normal on older engines that have been together for a long time.
Does anyone have a good picture of this?
I want to make sure I put the right amount in the right place.
Thanks
Clinton, NJ
Custom chopper, 1982 KZ 1000 M2 CSR engine, K&N Pod Filters
PICTURES AND GOPRO VIDEOS!! :
www.dropbox.com/sh/jipz3l8nhzr4jge/AABbm...OC3sqlhCSLxH5Fa?dl=0
10 Jan 2015 06:24
New gaskets have sealant made into them. Using it around oil galleys is dangerous. If you use it, just make the surface tacky not a bead. I don't use it on new gaskets. The surface must be clean, dry and undamaged for a good seal. You can and should make the large O ring that goes around the cam chain tacky. I use copper RTV silicon. The copper rings around the outer oil passages are meant to seal them as they compress. Using RTV to make them tacky is harmless but don't use it to seal the cylinders or anywhere around them.
- spdygon
Re: cylinder studs
10 Jan 2015 07:55
after market cylinder studs is a waste of money on a street motor. unless you plan on a turbo or super charger...or some of the existing one have tread damage.
1978 Kz1000 Z1R. 10K Miles1
1978 kz1000 z1r 27k miles
1976 Kz900A4 (Red)21K miles
1976 Kz900A4 ( Red)7500 miles
1974 Z1 900 project
1974 Z1 900 project
- KzChop82
10 Jan 2015 07:55
Steve- the large o ring around the cam chain area- do you let the copper rtv setup a bit? Or do you just put a bit on the run with your fingers before seating it and installing the cylinders?
Thanks, as always.
Thanks, as always.
Clinton, NJ
