cylinder studs
  • 123vucku
  • 123vucku's Avatar Topic Author
Re: Re:cylinder studs
10 Jan 2015 08:06
#658258
Yea was a bit skeptical when it came to using sealant on the cyliinder . Thank you
  • SWest
  • SWest's Avatar
  • 10 22 2014
10 Jan 2015 12:38
#658303
KzChop82 wrote: Steve- the large o ring around the cam chain area- do you let the copper rtv setup a bit? Or do you just put a bit on the run with your fingers before seating it and installing the cylinders?
Thanks, as always.
I make the O ring tacky as I'm putting it together. I don't care what it says on the package. It won't replace a gasket. I' ll also use it to hold something on while I'm putting it together. Too much and your buying yourself trouble.
Use the fine compound on your valves if the pitting goes away. SHIP IT.
