oil filter
  • eric77kz
  • eric77kz's Avatar Topic Author
oil filter
22 May 2014 21:32
#633581
No service manual or access to bike tonight. What oil filter should I pick up to return to my project tomorow? Need to change after 10 years. 77 KZ650 C1
77 KZ650 C
Re: oil filter
23 May 2014 03:57 - 23 May 2014 03:58
#633598
I use K&N 401 oil filters. I buy mine from Denniskirk.com but other places sell the (see links below). A lot of folks use WIX filters with success. Kawasaki filters are fine too. I recommend NOT using Fram filters as they are junk. When you change your oil be sure to buy oil that is marked JASO-MA compliant on the container. That will ensure the oil will not mess up the clutch in your bike. Most car oils will cause problems with the clutch because they have friction modifiers formulated not to hurt catalytic convertors. These friction modifiers, which are different than those in motorcycle oil or diesel oil, mess up the clutch friction plates. I use 10w-40 as recommended by Kawasaki. Ed
www.denniskirk.com/k-and-n/performance-g...03573.prd/303573.sku
www.autozone.com/autozone/parts/_/N-8gcs...entifier=594245_0_0_
Last edit: 23 May 2014 03:58 by 650ed.
The following user(s) said Thank You: eric77kz
  • koolaid_kid
  • koolaid_kid's Avatar
Re: oil filter
23 May 2014 04:56
#633603
Napa also sells motorcycle oil filters, they are rebranded Wix filters. RotellaT is a favorite among many riders due to its reasonable price and JASO-MA compliance. It comes in 15W-40 in dino fluid and is around $15 a gallon at Walmart.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
The following user(s) said Thank You: PLUMMEN, eric77kz
  • eric77kz
Re: oil filter
23 May 2014 18:57
#633714
Ok, got KN401 and oil. What is the proper torque for drain and filter cover bolts? Also how much does a 77kz650c hold?
77 KZ650 C
Re: oil filter
23 May 2014 19:40 - 23 May 2014 19:42
#633719
Engine drain plug torque is 9.5 - 12.0ft lbs. 10 - 11 ft lbs is enough; don't over tighten or you may strip a thread.
Oil filter mounting bolt torque is 13.0 - 16.0 ft lbs. 14 is enough; again, just don't overtighten it.
Be sure the bike is on the center stand (not side stand) when you drain the oil and change the filter. Total oil capacity is 3.5 liters (3.7 quarts). Don't overfill. The right side of the engine has an oil level sight glass (near the end of the brake pedal on the engine case). With the bike on the center stand add about 3 1/2 quarts (or a bit less) to an empty engine. See where that puts the oil on the sight glass. The level needs to be between the 2 lines; near but not over the top line is good. After you add the oil you may need to wait a fair amount of time before the oil level shows properly. You may even need to start the engine for a minute or so, then shut it off, give it some time, then check the level again. When the oil level stabilizes you can add a little more if needed to bring it up to the middle or closer to the top of the 2 lines. If you accidentally overfill it, put a piece of clear tubing into the engine through the filler hole and siphon some out (guess how i know :laugh: ) Ed
Last edit: 23 May 2014 19:42 by 650ed.
  • eric77kz
Re: oil filter
23 May 2014 20:20 - 23 May 2014 20:27
#633721
Well. I saw an old post from about 1.5 months ago youe were in ED. Talking to a guy about inches instead of foot lbs. So I bought a wrench that measures to 120 inch. Is there a conversion that would work? Also could you maybe post a pic of locations? Right now I am working from a Clymer which says 20-24 ft lbs for drain and 13-16 for cover and cant look at my bike right now to compare. The old post sent me looking for a "pan". I drive an hour to get to my bike right now
77 KZ650 C
Last edit: 23 May 2014 20:27 by eric77kz.
Re: oil filter
23 May 2014 21:32 - 23 May 2014 21:32
#633723
Get rid of the Clymer and get a Kawasaki Service Manual. If you try to tighten the drain plug to 20-24 ft lbs you will strip it and need a new oil pan. The engine drain plug torque is 9.5 - 12.0 foot lbs.
To convert INCH pounds to FOOT pounds you divide the INCH pounds by 12. So the maximum setting on a 120 INCH pound torque wrench equals 10 FOOT pounds. That would work for the drain plug since the proper torque for it is 9.5 - 12 foot lbs., but its a little too light for the oil mount bolt. In order to work on these bikes you really should have 2 torque wrenches. Take a look at the recommendation I made under "TOOLS" in the link below.
kzrider.com/forum/10-new-members/589649-...r-savannah-ga#594587
Personally, I have one torque wrench that is calibrated from 30 - 250 INCH pounds and one that is calibrated from 10 - 100 FOOT pounds. I also have one calibrated heavier for working on my car, but it isn't needed for the bike.
When you look under the engine you'll see the drain plug as shown and the oil filter mounting bolt in the middle of a round finned plate in the position shown below. Ed
Attachment 00007_2014-05-24.jpg not found
Last edit: 23 May 2014 21:32 by 650ed.
  • RonKZ650
  • RonKZ650's Avatar
Re: oil filter
23 May 2014 21:34
#633724
Well if you have an inch pound wrench the formula is twelve to one as expected, so if the spec is 10 ft/lb it would equal 120 in/lb on that tool. For filters you can use many as the size was common, CB750 Honda used same filter as did GL1200 goldwing. I bought like 20 goldwing filters in bulk for a good price many years back.
  • eric77kz
Re: oil filter
23 May 2014 22:18
#633729
Excellent Ed! Will do. I have a service manual on its way! 3-4 days tops. Hope I can help other people in the future too.
77 KZ650 C
  • PLUMMEN
  • PLUMMEN's Avatar
Re: oil filter
24 May 2014 21:13
#633856
No need to torque drain plug or filter bolt, snug them up with a 3/8 drive ratchet and call it a day.
Theres no reason to crank them down insanely tight, its only going into aluminum. :)
The following user(s) said Thank You: Patton
  • eric77kz
Re: oil filter
24 May 2014 23:08
#633872
What size are the filter cover and drain bolts on the pan?? My socket set did not have one to fit.
77 KZ650 C
  • KZB2 650
  • KZB2 650's Avatar
Re: oil filter
25 May 2014 04:48
#633881
17mm.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
