oil filter
- eric77kz
Re: oil filter
02 Jun 2014 07:11
17mm was right for the filter cover. I need to pick one up for the plug now what size is it? I have found some replacements that are 20mm is that right for mine?
77 KZ650 C
- KZB2 650
Re: oil filter
02 Jun 2014 07:43 - 02 Jun 2014 08:28
Both of mine are 17mm but then I've got a 78 Kz 650 B (same on my 79 parts bike although too) so not sure what to tell ya.
Just looked on Z-1 and your year and model comes with the same drain screw ....... You should probaly pick up one either there or at a dealer ...... you want the gasket to seal right and have no problems with the threads and length too.
1978 KZ650 b-2
700cc Wiseco kit 10 to 1.
Last edit: 02 Jun 2014 08:28 by KZB2 650.
- P21
Re: oil filter
02 Jun 2014 14:04
i dont what to start a pissing contest here,
as to inch lbs to ft lbs
this is another way
30 inch lbs X .08333 = 2.499 ft lbs
good day all and ride safe
this is another way
Kawasaki KZ 1000 Police (2002) P21
