O rings and seals for a 77 KZ1000 engine
  • bluej58
  • Topic Author
04 Mar 2014 07:09 - 04 Mar 2014 07:10 #624130 by bluej58
Does anyone know where I can find a complete list of O rings and seals for the 77 KZ1000 engine ?
I am ready to put this motor back together and I don't need any 11th hour surprises.
Thanks,
JD
78 KZ1000 A2A
Last edit: 04 Mar 2014 07:10 by bluej58.
04 Mar 2014 07:57 #624135 by 650ed
Replied by 650ed on topic O rings and seals for a 77 KZ1000 engine
Not a list exactly, but if you check out the parts diagrams on Kawasaki.com you should be able to compile a list. Ed
The following user(s) said Thank You: bluej58, wireman
04 Mar 2014 09:07 #624149 by Mcdroid
Replied by Mcdroid on topic O rings and seals for a 77 KZ1000 engine
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
04 Mar 2014 12:54 #624161 by moneypit
Replied by moneypit on topic O rings and seals for a 77 KZ1000 engine
650ed wrote: Not a list exactly, but if you check out the parts diagrams on Kawasaki.com you should be able to compile a list. Ed
+1
Thats what I did. Print the diagram out and had it at the bench. Found them all and ordered from Z-1
2-76 kz900
St Paul MN
  • TomW
  • Keep the blue side up.
04 Mar 2014 23:23 #624221 by TomW
Replied by TomW on topic O rings and seals for a 77 KZ1000 engine
bluej58 wrote: Does anyone know where I can find a complete list of O rings and seals for the 77 KZ1000 engine ?
Thanks,
JD
There aren't too many. Seals on the countershaft, the right end of the crank behind the centrifigal advancer, 3 on the shifter shaft, I think one on the kicker or maybe thats an O ring. There is an O ring between the case haves that seals the main oil passage . Z-1 sells a seal kit that covers all the seals. The O rings are seperate part#s. I may have forgot something, it's been 3 years since I put my engine together. Check the service manual and parts diagrams.
'78 KZ1000B2 LTD stock + Vetter Fairing & luggage
'91 ZG1200B5 Voyager XII, stock
05 Mar 2014 05:20 #624234 by LarryC
Replied by LarryC on topic O rings and seals for a 77 KZ1000 engine
If you have the oil pipe off from the top case [which you should so you can really clean out the galley] get 2 o rings for that as well.
Z1E probably has everything you need right on the shelf.
Larry C.
  • bluej58
  • Topic Author
06 Mar 2014 16:50 - 06 Mar 2014 16:55 #624374 by bluej58
Replied by bluej58 on topic O rings and seals for a 77 KZ1000 engine
Thanks guys, not including the 2 that you get with a Fram oil filter I count 15 O rings.
I'm going to go back over everything from the diagrams off of Kawasaki.com site but I think that is the count, I'll post an itemized list with Kaw's PO numbers soon hopefully.
Got the box from Z1 today with all the seals today along with a bunch of other stuff.
I plan on calling the local Kaw shop for the rings using their numbers , I did a lot of running around trying to get the right O rings for the 650 ,
I want to do this right the first time :dry:
There is actually 4 rings for the pipe with 3 different sizes
JD
78 KZ1000 A2A
Last edit: 06 Mar 2014 16:55 by bluej58.
  • bluej58
  • Topic Author
07 Mar 2014 11:09 #624432 by bluej58
Here's the list as per Kawasaki.com
The only one not available is the one on the starter motor shaft.
I ordered them through the local Kaw shop for $ 55.87 tax included
They are good on 77-78 A1, A2, A2A
78 KZ1000 A2A
07 Mar 2014 14:25 #624445 by 650ed
These folks have the one you're missing if it's part #21027-003. Ed
www.themotorcyclepartsoutlet.com/cgi-bin/store/index.cgi
22 Mar 2014 17:26 #626159 by Zedone
Replied by Zedone on topic O rings and seals for a 77 KZ1000 engine
Larry, what oil pipe are you talking about? Do you have a pic?
Thanks
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
22 Mar 2014 18:16 #626163 by bountyhunter
Replied by bountyhunter on topic O rings and seals for a 77 KZ1000 engine
Thanks,
JD
Some bizarre advice I got from the young guy at the parts counter at the local Kawi stealership: for O rings, think plumbing supply. The places that supply O rings for plumbing use have every O ring size on earth in every material.
When I rebuilt my engine, the Athena gaskets were bad and some failed almost immediately (including the cylinder base gasket) so I ended up having to tear it apart again and I needed some new O rings to put it back together.
The kawi dealer wanted about $12 EACH for O rings (any size) and that was when the parts guy took pity on me and told me to go to a plumbing supply place. I found a local warehouse that supplied O rings and went there and they had every size I needed in VITON material. I told the guy why I needed them and he just handed them to me and wrote 'customer sample" on the bill sheet (no charge). That probably saved me at least $00 compared to what I would have had to pay the stealership.
22 Mar 2014 18:18 #626164 by bountyhunter
Zedone wrote: Larry, what oil pipe are you talking about? Do you have a pic?
Thanks
I'll wager it's the pipe that goes between the cylinder and head with a restrictor orifice that feeds oil up to the camshafts. Those pipes have two O rings on them and are a bugger to get out of the cylinder. I had to knock mine out with a wooden dowel. mandatory to change those O rings.
