O rings and seals for a 77 KZ1000 engine
- Zedone
Re: O rings and seals for a 77 KZ1000 engine
23 Mar 2014 02:43
Thanks BH, I realized after posting what Larry was talking about. There called pin dowels, 2 upper 92043-1047 & 2 lower 92043-1266
1977 KZ1000A1
1977 KZ1000A1 (Superbike Project)
1969 Chevrolet C/10 Short Fleet
- bluej58
23 Mar 2014 07:58I went with # 21027-004 instead of # 21027-003
I went the plumbing route on my sons 78 kz650 and found a limited supply , the Stil chain saw dealer had a better selection of metric o rings and I trusted that they would be gas safe but still didn't have everything I needed.
I ended up going to the Kaw dealer for the balance.
This time I was looking for a quick fix and Kaw had everything excepted part #21027-003 which ended up being the wrong o ring anyways , it is the big internal ring in the starter that I will not mess with , the one I need is # 21027-004 that is on the out side shaft between the starter and the gear under the dyno cover cover :blush:
Ed found a good site for "O"rings but they only had about half of them.
Next time I will try to plan ahead and save some money but for 60 bucks I'm done are they are all numbered stock parts from the mother land and I have peace of mind that they should perform right .
The Oil pipe is on the left
JD
78 KZ1000 A2A
