- Thank you received: 83
Shim bucket opinons
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- Dr. Gamma
- Thank you received: 680
1986 RG500G 2 stroke terror.
- 4TheKZ1000
- Visitor
Home-slice at Pit Stop Performance says .418 can use shim on top.
www.pitstopperformance.com/kawasaki-z1-k...82-deg-030-lift-p-25
"The PSP-3X must be used with
heavy duty valve springs.
The PSP-3X has .418" lift with
282 degrees duration at .030" lift
The PSP-3X is the largest camshaft that can
be used with stock on top shims"
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- 4TheKZ1000
- Visitor
____________________________________________________________________Powerstroke_fan wrote: I dont have any safe way to properly sink the valve guides. But i do have a grinder. 4thekz1000 i remember seeing that but i also remember hearing people talking about spitting shims sometimes with even milder lift cam.
Call Joe and talk to him about it. Star was selling a .425 that they claimed was a SOT cam. Run it till it blows, you only live twice......come-on-man !!!!!!!!!!!!!!
I heard of a guy getting castrated by a spit shim using those PSP-3X cams..... :pinch:
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- gpz1170
- Thank you received: 10
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- les holt
- Thank you received: 288
Les
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- zed1015
- Thank you received: 1554
If I checked mine every 15 hundred miles i'd be in it every other month :laugh: .
I do mine every 8 or 9k miles.
