- Thank you received: 83
Shim bucket opinons
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
And Much Much more- SOLD
2014- ZX14R all stock for now
- zed1015
- Thank you received: 1554
This allows the opposite side to lift and they eventually flip out like tiddly winks if you are unlucky.
Before shim under, tuners used to fill the groove with silver solder etc to stop this happening and eventually you could buy performance buckets without the groove which seem to have totally disappeared now in favour of shim under items.
If your cam doesn't run that far over you will be ok.
It's easy to check for and sometimes you can actually see the shim lifting slightly when rotating the engine by hand.
Don't run tight valve clearances to compensate. It won't.
You want to be on the wide side for high lift cams. Yoshimura quote as wide as 0 .20mm for their ST cams .
- gpz1170
- Thank you received: 10
don
1974 Z1
1976 KZ900
1978 KZ1000
1981 KZ1000
1983 GPZ1100
- z1kzonly
- Thank you received: 540
You have no reason to go to 10,000. A waste of R's over the power band. I could never understand guys doing this??.
Nothing like the sound of 3X cams running about 1,500 rpm's, I always drove my bike all the way around the track. I did not tow it.
Just keep the valve clearence close. alot easier taking the cover off, than both cams out!
Here is an old picture I had.
Attachment shimstuff.jpg not found
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- Harvey1327
- Thank you received: 9
The deal with spitting shims is that a very high lift cam will run across the shim and rock the edge of it in the groove that runs under it around the edge of the bucket.
Makes a lot of sense and something that worried me since mine was built with shim over.
What size would be the maximin that you would advise for the slack shim over owners? :laugh: :laugh:
Thankyou.
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
- guitargeek
- Thank you received: 50
zed1015 wrote: Don't run tight valve clearances to compensate. It won't.
:huh:z1kzonly wrote: Just keep the valve clearence close.
1987 KZ1000-P6 "Ponch"
1979 GS1000 "Dadzuki"
- zed1015
Harvey1327 wrote: I have a 1327 with mild 365 lift cams and shim over bucket and had it at max revs down gardener straight at phillip island. Still in one piece. :whistle:
Thankyou.
I always go no less than 0,10mm on std motors and 0,15mm to 0,18mm on the cammed ones.
It's the Bucket groove that is the culprit.
ALL cams recommended for shim over have almost the same max lift and that is direct relation to how far they travel towards the edge of the shim.
Once you are there a combination of very high revs, Valve float, and shim rock will set up the conditions to fire a shim out.
Get rid of that groove and the chances of a shim going awol is almost eliminated.
- Powerstroke_fan
Ported J model head
Psp-3x cams
RS 36s
Welded MK11 crank
Back-cut MK11 trans
MTC 2 stage lock up
- z1kzonly
OUCH! No No, Don't grind your retainers down.They are hardened. Change them. I know J heads are similar, if you need a set of stock Z1-KZ style I'll give them to you.Powerstroke_fan wrote: i will put the shim over buckets back in. I will have grind down my retainers first tho. Then i will put it back together and check out how far towards the edge they go. If they look to be to close i will just put stock ones back in.
- turboking
- Thank you received: 106
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
- DFIGPZ
- Thank you received: 122
If you have to grind down retainers head is not set up correctly period. now onto the shim under buckets if you have them keep them if you are having to adjust valves all the time there is a problem back to head not being set up properly to begin with as for shim on top buckets I have done Many with .425 lift cams W/O issue the key PROPER SET UP.Powerstroke_fan wrote: i will put the shim over buckets back in. I will have grind down my retainers first tho. Then i will put it back together and check out how far towards the edge they go. If they look to be to close i will just put stock ones back in.
1984 750 Turbo
