Will GPZ1100 1982 Gear assemblies fit a KZ1000
- Bozo
- Ride it like u stole it
05 Nov 2013 04:42
My Z1R has just suffered its first major breakdown, after the hard life it had something had to go. The bottom end is still original and has now done over 200K kms, my sprocket shaft feels like one of the internal bearings has lost its roller cage.
I have a brand new GPZ1100 engine (the bike fell off a truck before a race meeting with 50kms on the clock), now to my question, will the gear clusters, bearings and clutch fit my Z1R casings.
I know the GPZ drive shaft has a bigger diameter and the clutch is different in size.
If this has been discussed previously let me know, I couldn't find anything on this topic
- GPzEric
Re: Will GPZ1100 1982 Gear assemblies fit a KZ1000
05 Nov 2013 07:44
I don't think they are interchangeable with your 1015 engine. I think that the parts are interchangeable only from the 1981-1983 KZ1000J motors.
My wife asked me if I still loved her - I said "Honey, I love you more than new carburetor boots ! "
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
(2) 1981 KZ550D1 (GPz) 1 mint, 1 under construction
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
- Mcdroid
- Gone Kwackers
05 Nov 2013 09:14GPzEric wrote: I don't think they are interchangeable with your 1015 engine. I think that the parts are interchangeable only from the 1981-1983 KZ1000J motors.
+1
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- turboking
05 Nov 2013 14:54
yes ...drag racers have used a gpz conversion for years to put a gpz trans into z cases :blink: .... different bearings and some machine work on the shift drum and some gears ..... :S go to dragbike.com and check, fitting GPZ gearbox into kz cases
KZ zone
HDB1130528 Transmission conversion bearing. Allows the installation of a GPZ1100 transmission into a Z1/KZ1000 cases without the need for special shafts. 79.95
KZ zone
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
The following user(s) said Thank You: GPzEric
- Bozo
05 Nov 2013 15:25
Thanks guys, it was just a thought, although Turboking has me want to try. First I'll find out what requires changing before I panic, thanks for your input. :sick:
- jeffasaki
05 Nov 2013 17:45
my 2 cents
install a brand new gpz1100 engine into a 78 z1r frame and ride
whille you ride think about rebiulding the 78 then get it done
that way youll have a fresh motor ready after the next 200 000 km
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
- Bozo
05 Nov 2013 23:52
Sounds great BUT....
The sad part is that the Z1r top end is fantastic, the bike goes like hell, is smooth uses bugger all oil, sounds like new (no rattles), basically the GPZ motor would require a fair bit of work on the topend to equal the Z1R. The GPZ motor itself (from what I heard) requires work to fit in the Z1R frame anyway.
I was really hoping to to just install a new gear set (the easiest option) but the more I read, I might as well fix the current setup.
- Mcdroid
- Gone Kwackers
06 Nov 2013 00:16turboking wrote: yes ...drag racers have used a gpz conversion for years to put a gpz trans into z cases :blink: .... different bearings and some machine work on the shift drum and some gears ..... :S go to dragbike.com and check, fitting GPZ gearbox into kz cases
KZ zone
Thanks...I learn something new every day.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
- Harvey1327
06 Nov 2013 00:59
You might be able to pick up a Z650 frame cheap. ??????????
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
- Bozo
06 Nov 2013 04:19
Harvey, sounds good but I'm starting to get too old to piss fart around with odd bikes. My FJ1200 is giving me headaches without making hybrids.
Turboking, I must've been asleep when I read your comment, somehow I missed the kz zone conversation comment, thats brilliant mate, thankyou :woohoo: :woohoo:
- Bozo
06 Nov 2013 15:11
Turboking, I'll go on a limb and ask if the clutch basket from the GPZ1100 (1982) will fit onto KZ1000 cases
- GPzEric
07 Nov 2013 06:21
Good info turboking -
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
1982 KZ1100B2 (GPz)
1982 KZ750R1 (GPz)
1983 GS1100E
