Will GPZ1100 1982 Gear assemblies fit a KZ1000
- turboking
Re: Will GPZ1100 1982 Gear assemblies fit a KZ1000
07 Nov 2013 08:42Bozo wrote: Turboking, I'll go on a limb and ask if the clutch basket from the GPZ1100 (1982) will fit onto KZ1000 cases
here is the deal.....
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
1985 GS 1150E
1983 GS 1100E
- Bozo
- Ride it like u stole it
07 Nov 2013 15:27
Again thanks mate, I have to admit even though the Z1R has had a hard life, I had the clutch hub damper springs changed at 60,000kms with heavy duty ones (before it rattled like a Ducati clutch) since then its been quiet with no problems. I was just curious more than anything else. As usual your input is appreciated.
- Harvey1327
07 Nov 2013 15:46Bozo wrote: Again thanks mate, I have to admit even though the Z1R has had a hard life, I had the clutch hub damper springs changed at 60,000kms with heavy duty ones (before it rattled like a Ducati clutch) since then its been quiet with no problems. I was just curious more than anything else. As usual your input is appreciated.
I just sent you a pm without reading this post :silly:
I need to replace my springs in my clutch hub, did you do it or someone else and how did they get the hub apart besides grinding the studs /plugs /rivets (whatever the're called) how much pressure did it take to push them out?? We have tried but the press wasn't big enough.
Cheers
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
Akron rims,Martin Swingarm
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
shotgun shock,corbin
seat,fat bars,some bling.
www.kzrider.com/media/kunena/attachments/8119/IMG_0461.JPG
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
- 4TheKZ1000
07 Nov 2013 17:51 - 07 Nov 2013 17:53
Is there a difference in gear ratio between the gpz 1100 trans and a mark II ?
Would really like a gear range thought-out the box for top end and pass on off the line.
Last edit: 07 Nov 2013 17:53 by 4TheKZ1000.
- Bozo
07 Nov 2013 18:10
I didn't do the job myself it was done about 30yrs ago by Mick Hone motorcycles Victoria Australia. He used to be one of the top racers in them days. What he had done is to cut/grind the tags holding the springs fit heavy duty ones (I think they were GPZ1100 springs?) and reweld the tabs so there was no free ply on the springs, then he checked for balance (didn't need any re balancing).
I do believe that these days they cut the rivets and and re-rivet but I don't know who does this. Till this day (over 140,000kms) my clutch has no rattles (shame about the old bastard on the bike at higher speeds :laugh: )
As for the gear ratios it shouldn't be hard to find them on the web but I would be interested to hear if the gears make a noticeable difference as well, if so how/where?.
- 4TheKZ1000
07 Nov 2013 18:49 - 07 Nov 2013 18:50
www.kzrider.com/forum/2-engine/266607-gpz-transmission
sell.dragbike.com/detail.asp?id=287&n=Ka...-fit-in-KZ1000-cases
Last edit: 07 Nov 2013 18:50 by 4TheKZ1000.
- Harvey1327
08 Nov 2013 03:05
Don't if this will help
www.gearingcommander.com/
1 x 77 Z1000
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
1080,cams,ported
29 smoothbores,
1 x 77 Z1000
1327 Wiseco,cams
ported,34.5 S/bores
GSXR swingarm
RF900 frontend.
1 x 2008 Nightrain
- Bozo
20 Nov 2013 15:59 - 20 Nov 2013 16:01
I made a mistake with my last reply. When I pulled the engine apart, it also gave me a chance to check the clutch hub and how it was repaired, I found that the rivets were ground around the sides and once the springs have been replaced they were welded back.
I'll be happy to post photos if anyone is interested. I don't know why I thought the tabs were rewelded - it was done over 30years ago. Now where was I, who are you? :laugh: :silly:
Last edit: 20 Nov 2013 16:01 by Bozo.
