Clutch cable snapped from handle
  • toadson
  • toadson's Avatar
Re: Clutch cable snapped from handle
13 Oct 2013 02:02
#609822
I had my clutch cable break a few months ago while riding on the highway, right at the clutch lever. Luckily I only needed to make one turn onto my road and then into my driveway. I was on a 50+ mile ride, so I lucked out. I had to keep adjusting the clutch tighter throughout the ride, so I had a feeling it was about to let go. After installing the new cable, I couldn't believe how much better my clutch felt. I'll be sure to keep it properly oiled from here on out!
79 KZ1000 LTD. Mikuni VM26 w/ accelerator pump. 4 into 1 header. Stock intake setup. GS1100 Swingarm, My swap thread: kzrider.com/index.php?option=com_kunena&...d=5&id=210872#210872
  • MDawnz1
  • MDawnz1's Avatar
13 Oct 2013 02:46
#609824
Jeff.Saunders wrote: There's a few things to check.
The cable barrel end should pivot in the lever. If it's too tight, it will cause a premature failure right at the upper end nipple. Clean the area in the lever and if necessary smooth any imperfections in the barrel on the end of the cable. A silicone lubricant is good as it won't attract dirt.
Check the cable adjuster. Many of these have rough edges. A small file can help relieve any of these.
Make sure the cable is routed correctly. If the handlebars have been changed it's possible you may need to reroute the cable so it isn't too tight a turn at the handlebar end.
All good advice,
An older rider told me a long time ago,
If you love to ride and love your bike,
Buy it a Christmas present EVERY year,
NEW CABLES ! And put them on during winter.
Whats the down side?
Spare used but OK cables?
I have not been stuck or having to wait for a replacement for many years.
Mike
1974 Z1a, still 903
  • CrazyDuck
  • CrazyDuck's Avatar
13 Oct 2013 11:23
#609847
I like to spray cleaner down the cable and remove all the old, nasty, gummy oil residue before re-oiling. I noticed this helped make the clutch feel muck better than just adding to the sludge. Good way to get an old gummy cable to work better and actually last.
1976 KZ900
1974 TX500
1978 TT500
2007 Aprilia SXV
  • Nebr_Rex
  • Nebr_Rex's Avatar
13 Oct 2013 12:03
#609851
I also carry extra cables.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
  • david-b
  • david-b's Avatar Topic Author
  • I am THAT guy
21 Oct 2013 10:24
#610687
Finally got the new cable installed yesterday and am super happy with the results. Took everyone's advice and did what the manual said and it feels like the clutch on a brand new bike. Cleaned and lubed up everything. The clutch release mechanism had a ton of built of crud on it. It's never felt this good. Only takes a couple fingers to pull it down now and just feels great.
Only issue, the cable was longer than the one I took off. I temporarily zip-tied it to the speedo cable for the time being, but when I turn the handle bars to the right, the clutch cable hits the front tire and looks dangerously close to going between the fender and the tire. I've got it running up from the trans, through the bars and to the handle. Any better way to do this?
/Dave
2013 Chevy Sonic LT 1.4L Turbo
1982 Kawasaki KZ750-H3 LTD
1975 Monte Carlo 400sbc
  • martin_csr
  • martin_csr's Avatar
21 Oct 2013 14:02
#610714
Get a shorter cable? ... what cable was installed?
Does your bike have cable clamps on the frame &/or a cable guide at the handlebars?
  • sbc1320
  • sbc1320's Avatar
21 Oct 2013 14:42
#610716
The same thing just happened to mine. Got on the net and ordered 2 new cables. Lubed the new cable, installed, and adjusted all 3 places. Works so much smoother than before, plus I do have APE clutches and springs. Mine is shorter than stock because of the "Superbike" bars. Mine is the 03-0030 Motion Pro. Cable length is going to be different on any bike that has non stock handle bars.
1980 KZ1000 LTD-B4(MK II engine) - Progressive suspension, MTC pistons, Dynojet Stage III, all wear items replaced, WFO paint scheme(1978), etc..
Past bikes- 2 1976 Kz900's, 5 1975-76 Honda CB750's, Honda 500 -4, Honda 250, Honda 125, Honda 100, Suzuki RM 250, Honda XL350, Kawasaki KLR 650, etc..
  • david-b
  • I am THAT guy
21 Oct 2013 14:59
#610717
martin_csr wrote: Get a shorter cable? ... what cable was installed?
Ordered one for Z1. Not sure what the cable guide is, but no clamps. I seen Z1 does have clutch cable-to-frame clamps that I may pick up.
/Dave
  • martin_csr
21 Oct 2013 15:15 - 21 Oct 2013 19:19
#610720
You may have ordered or received the wrong cable, perhaps the one listed for the 750H Ltd?
The Ltd clutch cable is almost 10" longer than the one Z1Ent has listed for the GPz.
Their part numbers are similar - only the last digit is different.
I installed the GPz MP03-0030 onto my 650 & even without the clip it wouldn't be near the wheel/fender.
The Partzilla Cables diagram shows 2 frame cable clips, but I'm not sure they are both for the clutch cable.
I'm assuming your bike is the 82 GPz750 R1.
Last edit: 21 Oct 2013 19:19 by martin_csr.
  • david-b
  • I am THAT guy
21 Oct 2013 15:30
#610721
Pretty sure I have this one, will have to check when I get home. This was the one that shows up in the KZ750-H3
www.z1enterprises.com/ItemDetails.aspx?i...Z1000&item=MP03-0033
Why do no parts ever fit for this bike!?
/Dave
  • martin_csr
21 Oct 2013 15:44 - 22 Oct 2013 11:43
#610723
david-b wrote: Pretty sure I have this one, will have to check when I get home. This was the one that shows up in the KZ750-H3
The 750H Ltd has mini ape-hanger handlebars, so it uses a long clutch cable which is too long for Standard model & GPz handlebars.
You probably need MP03-0030 which is 49.5" long - Z1Ent has it listed for the 82 R1.
But verify for yourself whatever clutch cable is correct for your bike. Measure the old cable & measure the slack... don't ignore the slack as it may matter. I found that out the hard way when I got throttle cables. doh.
Last edit: 22 Oct 2013 11:43 by martin_csr.
  • Dr. Gamma
  • Dr. Gamma's Avatar
21 Oct 2013 15:49
#610725
Think you should have ordered #03-0030. It shows its for the 750R and the 750L model Kawasaki's
The cable you have is for the tall LTD style bikes.
But what do I know, I'm just a stupid former parts person with too many years behind the counter.
1986 RG500G 2 stroke terror.
